Replacing Front brake pads - SaabCentral Forums
Old 5th April 2010
jswain jswain is offline
My Saabs: 99' Saab 95
Default Replacing Front brake pads
I am replacing the front brake pads on my 1999 Saab 9-5. I can't get the caliper off though. I only see two bolts on the back side of the caliper and they are both very stuck. Do I have to remove these to replace the pads or is there something I am missing? If there is a "how-to" somewhere for my model can someone point me in the right direction. I have looked but can't find anything for the 9-5
Thank you very much
Old 5th April 2010
gghh gghh is offline
My Saabs: BMW 530D Touring xDrive
Try the faq.
Old 5th April 2010
vagrantradio's Avatar
vagrantradio vagrantradio is offline
My Saabs: 2002 9-3 HOT
Garage
It may be that the piston is so compressed on the rotor that you may need to use force. Make sure all bolts are out and you should be able to wiggle it off.
Old 6th April 2010
Xanimal13 Xanimal13 is offline
My Saabs: 2001 9-5 Aero A/T
When the bolt wont come loose I just grab my trusty 2' breaker bar
Old 6th April 2010
88mmm 88mmm is offline
My Saabs: 2002 9-5 Aero
To do the pads only it is not necessary to remove the carriers. You need to remove the sliders with a 7mm Allen wrench and they should come out fairly easily. They are located under black caps on the back of the caliper, one top one bottom.
88 M3 (Fighter Jet), 05 Jetta GLI (Learjet), 02 9-5 Aero (Jumbo Jet)
Old 6th April 2010
jimbsaab jimbsaab is offline
My Saabs: SAAB 93 2008 TTDI SPORT
Default brake pins
when you remove the pins put some copper grease on them to stop them sticking. the 7mm brake key is allso used on older fords you can get one
at local spares shop. the bolts undo clockwise
Old 6th April 2010
Paul in NM's Avatar
Paul in NM Paul in NM is offline
My Saabs: 6 former Saabs
Mine were a bugger to remove. The PO had way too much blue loctite on the bolts and I had to use a breaker bar to remove them. Ever since replace the front pads my alignment seems off. Wondering if putting so much pressure/force on the bolts jarred it out of alignment.
Old 6th April 2010
MI-Roger MI-Roger is offline
My Saabs: '08 9-5 Aero, '06 9-3SC, '00 Viggen
SAAB is famous for changing fastener styles w/o notice, but the front caliper bolts on my 2000 are Torx head.
Old 7th April 2010
toxicavenger's Avatar
toxicavenger toxicavenger is offline
My Saabs: 2006 9-5 Sedan, 2006 Sportcombi
You must be a tough dude to knock your alignment out by hand.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
