side view mirror glass fell out?!!! - SaabCentral Forums
Old 5th April 2010
multistrada74 multistrada74 is offline
Default side view mirror glass fell out?!!!
fell out while driving on my 2004 93 arc. can you guys please tell me where i can simply order one piece of glass for the passenger side? does it just glue on? thanks.
Old 5th April 2010
tbutera2112 tbutera2112 is offline
My Saabs: '04 9-3 aero 6spd
yea it just glues on...happened to me...mine was driver side though, i heard its more expensive for passenger side since its a weird mirror
quick google search the drive side glass can be found anywhere, but the passenger side i cant even find...you may have to order it from a dealership or a collision shop that knows where to get it
Old 5th April 2010
Ignatius Ignatius is offline
My Saabs: 2003 Saab 9-3 Arc 6 spd
It has a metal clip that wraps around it and will snap snuggly into place. You can pick up a replacement mirror at the link. This will cost $35.65 USD shipped and is the best deal available - It is not an OEM part but is near identical with the wide view and also has heating. Im thinking about picking one up for my left side because it has the wide veiw.
http://cgi.ebay.com/SAAB-9-3-RIGHT-S...item3a4c00b302
Old 5th April 2010
GlassGrey GlassGrey is offline
My Saabs: 2008 93 SS, 2004 93 Arc Convertible
Quite a few of the car accessory folks carry replacement glass too.
If you want something truly special, ask for an autochromatic version to tone down the glare at night... can't believe these machines don't have that or an auto dim RV mirror....
Born to Drive
Old 6th April 2010
Mithos the Hero Mithos the Hero is offline
My Saabs: MY03 Saab 9-3 Linear 2.0t
I bought aftermarket anti glare ones on ebay for 40 bux after one of my mirrors got taken out. Surprisingly the anti glare works great at night with SUV and both mirrors have the convex lensing. Surprised the hell out of me .
Old 6th April 2010
Saabseeker's Avatar
Saabseeker Saabseeker is offline
My Saabs: 2005 Saab 9-3ss Linear
Mine got loose and began vibrating going down the road one morning. When I got to work, I realized the mirror glass itself was hanging on by the proverbial thread to the plastic backing plate that attaches to the motor. I removed the glass the rest of the way, and then glued the glass back onto the plastic backing using 3M "Windo Weld" urethane adhesive #08609. Stuck that sucker back on solid and the heat still works since it's in the backing (just doesn't defrost quite as fast since there's a new layer of glue in there).
2005 Saab 9-3SS Linear (daily driver)
2006 Yamaha Morphous
2008 Kawasaki Ninja 500R
Old 2nd July 2010
2003 Ron Burgundy 2003 Ron Burgundy is offline
New Member
My Saabs: 2003 9-3 ARC 2.0T
Default 9-3 ARC Turbo - Side mirror glass
I followed the eBay link and that's exactly what I need, but I can't wait for it to be shipped from the UK. Any other options that are local? I'm in the Chicago area.
Old 8th October 2015
furgs's Avatar
furgs furgs is offline
My Saabs: 2007 9-3
Garage
thanks! I just picked up the 3m Windo Weld. did you try to remove the old layer first before putting on the plastic part?
Old 9th October 2015
Stratixman Stratixman is offline
My Saabs: '03 ARC 6 speed MT. Steel Grey.
If the mirror is heated then be careful about not disturbing the black backer material left on the mirror mounting plate as that is what contains the heating elements. Use isopropyl alcohol or similar to clean/remove any residual adhesive left from the original mounting on both the mirror and backer plate. Use as thin as possible of a layer of glue to remount the glass to the backer plate or the heating functionality may be impaired. I think silicon is probably too thick to use. When I reglued mine I used Seal-All contact adhesive made by Eclectic products. http://eclecticproducts.com/seal-all.html . It provides a secure bond without introducing too much thickness in the glue component, plus it withstands a wide range of temperatures.
900t's Avatar
900t 900t is offline
Saabista
FWIW I've always used my tube of "do anything" black goop glue
I've been looking at mirrors held in with it for the past 10 years and didn't fall out, so I think, a successful application.
I tried using it on a convertible rear window, this failed (2 part epoxy works much better)
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
