2002 9-3 Neutral Safety Switch - SaabCentral Forums
Old 17th March 2010
Nobranflakes Nobranflakes is offline
My Saabs: 2002 9-3 SE
Default 2002 9-3 Neutral Safety Switch
Hi Guys,
I got a new (for me) '02 9-3 a little back and it's been a dream of a car, but I've had problems lately with the car not starting after being driven, usually 10-15 minutes takes care of the problem, althought sometimes (usually when it gets suddenly cold) the car won't start even if I leave it alone 30 minutes, an hour, I've been stranded overnight twice now. My father had a 2002 9-5 with the same problem, he replaced the NSS and hasn't had a problem since, i've ruled out the CPS or anything but the NSS after reading on these forums and others. Problem is, I really don't have money to buy a new NSS even if I did the labor myself with a friend. I was laid off recently and am currently in school, just bad timing.
I was reading about the paperclip bypass, but can't find any clear pictures or diagrams of where exactly this goes and I don't care to mess anything up on my car. While looking around the engine yesterday I found a small stripped wire with 2 strands in a crevice in the engine bay which makes me think the old owner might've been using this bypass. If anyone has a picture/diagram/clear instructions on how to bypass this NSS until I get the money to fix it I would really appreciate it. Thanks so much
Old 17th March 2010
Just left me stranded (at home luckily) again.
Old 18th March 2010
earthworm's Avatar
Saab Sage!
This NSS neutral safety switch, from what I have read, can be disassembled, cleaned, relubed, reinstalled.
http://www.saabcentral.com/forums/sh...d.php?t=129988
There is more; troubleshooting must be done.
The earthworm
'96 900S, Automatic
Old 18th March 2010
john bernard john bernard is offline
My Saabs: 1995 900SE convert. V6
You didn't say whether or not the starter will crank the engine. If it will, the NSS isn't the problem.
EZRYDR
Old 18th March 2010
Frank_Drebin's Avatar
Frank_Drebin Frank_Drebin is offline
My Saabs: '96 900 `04 9 Arc Vert
I will start my answer by saying that John Bernard and I respectfully disagree on the NSS and bypassing it as a fix. i think it is a weak link that serves no useful purpose and should thus be bypassed permanently. None of my Saabs has the NSS intact even if they weren't exhibiting any issues. ASSUMING the NSS is your problem, the fix is simple and straight forward. (If your engine turns when you turn the key, look elsewhere).
Here's the simple fix for the 9
Here's the bypass for a 900
Old 18th March 2010
A few more pics that may help:
Old 31st March 2010
nthny nthny is offline
New Member
My Saabs: 2001 9-3
I just had my mechanic perform this quick fix and it worked brilliantly. I now own the car I meant to own when I bought it. My 2001 9-3 has just been, in twenty minutes, transformed from a recalcitrant non starting waste of a beautiful car to a beautiful, perfectly tuned 9-3 that actually starts every time. Thank you Frank for your amazing fix! Don't hesitate in doing this to your Saab if it's not starting.
Old 31st March 2010
sankuspr's Avatar
sankuspr sankuspr is offline
My Saabs: 2005 9-5 Aero Sedan. Chilli/charcoal MT
Originally Posted by Frank_Drebin View Post
I will start my answer by saying that John Bernard and I respectfully disagree on the NSS and bypassing it as a fix. (If your engine turns when you turn the key, look elsewhere).
Am i missing something?
It really is that simple.
Old 31st March 2010
Nope...
EZRYDR
Old 31st March 2010
Nope...
Old 1st February 2013
Letsdothis Letsdothis is offline
New Member
My Saabs: 2002 Saab 9-3 se
Default Making sure I have this correct.
Hi, I've been reading up on this bypass and it looks like my 02 Saab 9-3 se is going to need this. I just want to verify a few things considering I'm not all that well with schematics..
So to do this bypass basically what I need to do is take a piece of wire, connect it to the bottom lead of fuse 36. Push the fuse back in. Then, take the wire from the fuse I just installed and use a quick connector to wire it into the grn/blck wire on the starter relay (pin 86). Is this correct? I do appreciate your guy's advise thus far but please help!!
Thanks in advance.
Old 15th February 2013
Bob Klein Bob Klein is offline
My Saabs: 2000 9-3 Base Model 4-Door Hatchback
Yes, that's it, but there are some wrinkles. I recently did this with my 2001 9-3. It is a bit of a struggle to get the panel under the steering wheel off; on mine, there was one 10 mm bolt, 7 or 8 torx head screws, 2 push pin connectors (very delicate), and a hookup for a auxiliary battery supply or Tech-II sensor (not sure) to disconnect. The wire coming out from the back of Fuse 36 is easy enough (red/green on mine); however, the wire from pin 86 was, on my Saab, black and white. So I unscrewed the torx screw that held the relay box up and worked the entire box free (took some careful manipulating, but you can figure it out by looking at it - the front drops down, the rears have to slide forward before they'll drop down; it doesn't give up without a fight). I removed the starter relay to confirm that the black and white wire was in fact hooked to pin #86 on the relay - it was - and I went from there. So far the car has started every time, no problem; HOWEVER, I am getting transmission and a gear wheel/exclamation symbol idiot lights on my panel, which based on the comments on this forum was unexpected. So, at least for me it appears that I will HAVE to put in an in-line switch into the bypass, as several folks have already suggested on this forum. Hope this helps and good luck.
Old 6th March 2013
An Update to my last post. About a week after doing the above work, I disconnected the negative battery cable to install new plugs. When I reconnected the cable and started the car, the "transmission" (gearbox) and "gear-wheel/exclamation symbol" (CEL) idiot lights had self-cleared. The bypass still works (I put the car in gear and "tapped" the ignition to prove it). So it seems I don't need a switch in the bypass after all, though I'll install one anyway if I ever sell the car (I ordered a 12 volt doorbell switch to do it, if I ever need to). Again, hope this helps.
Old 21st May 2013
JohannaSan JohannaSan is offline
New Member
My Saabs: Martin the 1998 900S turbo 5 speed
Frank, thank you for sharing this fix. I'm glad to have my car running again.
Johanna
Old 6th April 2014
tstaples85 tstaples85 is offline
New Member
Curious if there are similar starting circuit diagrams for the 2001 9-5. I would like to do this fix but cannot seem to get all the info together. My fuse number 36 in the 9-5 is for my power windows. Don't think that would give me great results I have no idea what fuse 36 goes to on the 9-3. I have scoured the interwebs with no luck.
Old 13th July 2015
PackN1 PackN1 is offline
New Member
To bypass on a 2000 Saab 9-5 V6 run jumper from fuse #30 to #86 pin on the relay....
used a Momentary push button switch from home depot... and 4 feet of 22ga wire. total cost $5.
I was actually able to replicate the issue tonight right in my driveway.... ran it till it got hot and parked it for 5min, turned the key and it didn't do anything at all and wouldnt start or turn over like the 5 other times this has happened.... so without even letting go of the key (<-- still in start position) I hit the bypass switch and fired right up!!! HOOORAH!@!!! 100% confirmed neutral saftety switch was the problem & issue fixed (((bypassed)).
Old 13th July 2015
Jeremy R.'s Avatar
Jeremy R. Jeremy R. is offline
My Saabs: '97 900SE Talladega, 2000 9-5 Aero Wagon
There's an even easier way to bypass it. The NSS plug in the engine compartment has a black and a white wire. Snip them, and connect them at the plug end. No switch needed, no messing with the fuse panel, and it's easily undone if you want to disassemble and clean the switch.
Old 13th July 2015
New Member
Great idea to permanently bypass the NSS entirely Jeremy, the cool thing about this method is it retains the safety function of the switch.... it wont allow me to start the car in gear unless I am holding the added button. (tested)
Old 5th November 2015
scalambra scalambra is offline
New Member
Thanks for this really useful post. I am about to get the same thing done to my 2002 9-3SE. Have you got a better res scan of the starter circuit that I can give to my electrical guy please?
Thanks!
Old 26th November 2015
bmeltzer2 bmeltzer2 is offline
New Member
Default NSS Bypass
Can I get a picture of what the end result looks like so that I can do this.
My 2002 9.3 SE wont start and I need a quick and easy fix
thanks
Ben Meltzer
ben.meltzer@gmail.com
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
