Takes a long time for my engine to start? turns over too much. - SaabCentral Forums
Old 15th March 2010
gageissocool gageissocool is offline
My Saabs: 1999 Saab 9-3 turbo 2.0 5dr
Question Takes a long time for my engine to start? turns over too much.
car: 1999 saab 9-3 turbo
my car turns over an average of 5-6 times before starting. everytime. sometimes more. but runs fine after its started. why?
thanks
Gage
Old 15th March 2010
Ero's Avatar
Ero Ero is offline
My Saabs: '01 9³SE
I think that's just the way the cars are.....Mine turns over 3-6 times depending on the outside temperature....2-3 if i just drove it... my dad's acura turns over like.....once, lol.
Old 15th March 2010
earthworm's Avatar
Saab Sage!
IMO, this does have a meaning; but for this event to have a diagnostic value, the actual timing must be done by the car's ECU and in milliseconds. If the fuel check valve is slow or leaks just a tiny bit, then the time will be longer I think this very slight delay may aid in engine life.....one second longer for oil pressure to amass before combustion pressures....
2 to 4 turns for me, less when cold.
The earthworm
'96 900S, Automatic
Old 15th March 2010
Twitchie Twitchie is offline
My Saabs: none
Mine usually turns 5-6 times before starting. Seems normal to me.
Old 16th March 2010
Frank_Drebin's Avatar
Frank_Drebin Frank_Drebin is offline
My Saabs: '96 900 `04 9³ Arc Vert
You most likely need a fuel pump check valve. The check valve keeps the fuel from draining back into the tank after you shut the car down. If the valve is stuck open then the fuel lines are empty or at least not full when you start your car. You will have to wait for the fuel to go through the whole fuel system each time. It's an easy, cheap fix. I had to do the same to all of my Saabs at around 70k.
Old 16th March 2010
Ero's Avatar
Ero Ero is offline
My Saabs: '01 9³SE
any pix/tutorials?
This might explain why my car stalled out 2-3 times after sitting in my garage for a week. I actually got scared and thought it died n then it sputtered to life which made me
Tags
hard to start, idle, turbo over
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
