SID error messages - List - SaabCentral Forums
Old 19th November 2003
Saba's Avatar
Saba Saba is offline
Default SID error messages - List
This is what SID can display.
A/C off due to high engine temperature.
Antilock brake malfunction. Contact service.
Stability control failure. Contact service.
Traction control failure. Contact service.
Use your seatbelts.
Rear right seat backrest unlocked.
Rear left seat backrest unlocked.
Battery not charging. Make a safe stop. Contact service.
Reduced engine power. Contact service.
Brake malfunction. Make a safe stop. Contact service.
Remote control battery low. Replace battery.
Time for service. Contact service.
Rear fog light failure.
Tire pressure system failure. Contact service.
Lock system failure. Contact service.
Incorrect part detected. Contact service.
Release park brake.
Hot engine. Make a safe stop. Run engine on idle.
Right rear turn indicator failure.
Right brake light failure.
Right front turn indicator failure.
Right low beam failure.
Right high beam failure.
High mounted brake light failure.
Immobiliser failure. Retry to start. Contact service.
CHECK OK
Airbag malfunction. Contact service.
Headlamp levelling malfunction. Contact service.
Brake fluid level low. Make a safe stop. Contact service.
Coolant level low. Refill needed.
Low engine oil level. Fill oil now.
Washer fluid level low. Refill needed.
Tire pressure low, rear right. Check tires.
Tire pressure low, front right. Check tires.
Tire pressure low, rear left. Check tires.
Tire pressure low, front left. Check tires.
Oil pressure low. Make a safe stop. Turn off engine.
Engine malfunction. Contact service.
Key not accepted. Contact service.
Parking Assistance malfunction. Contact service.
Right rear position light failure.
Left rear position light failure.
Tap brakes lightly before using cruise control.
Flat tire rear right. Make a safe stop.
Flat tire front right. Make a safe stop.
Flat tire rear left. Make a safe stop.
Flat tire front left. Make a safe stop.
Lock engaged. Pull out key, turn steering wheel. Retry to start.
Steering lock malfunction. Make a safe stop. Contact service.
Parking assistance sensor disturbed.
Tighten fuel filler cap.
Close doors.
Alarm activated during last arming period.
Theft protection failure. Contact service.
CHECKING
Valet mode activated.
Left rear turn indicator failure.
Left brake light failure.
Left front turn indicator failure.
Left low beam failure.
Left high beam failure.
Gearbox malfunction. Limited performance. Contact service.
X: standard key Y: valet key Key No: Z
Gearbox too hot. Make a safe stop. Open hood to cool down.
Your driving too fast
You sure taught that ricer a thing or two
JNGold's Avatar
JNGold JNGold is offline
Thanks Saba! That's definately FAQ material!
I hope never to see any of those messages (except the ones that say "OK" or "Activated"), especially the "driving too fast" one. :wink:
Although, I wouldn't mind seeing the last one! :wink: 8)
03_Saab 9-3 03_Saab 9-3 is offline
Default Re: SID error messages - List
Wow, Great list, these are ones i have seen when i had my first few months of quirks.
Immobiliser failure. Retry to start. Contact service. (Ignition Replaced)
CHECK OK
Headlamp levelling malfunction. Contact service.(Headlights replaced)
Key not accepted. Contact service.(Ignition replaced-keys recoded)
Lock engaged. Pull out key, turn steering wheel. Retry to start. (was my bad didnt know how it worked)
Steering lock malfunction. Make a safe stop. Contact service. (Ignition replaced)
italiancousin italiancousin is offline
What's the valey mode all about?
Also, the complete list seems to lack the rear seat lock warnings...
Old 20th November 2003
WopOnTour's Avatar
WopOnTour WopOnTour is offline
My information states that while SID has the potential to display all of these messages (and more), many are market or option specific.
The valet parking feature may be the exception, as it appears to be unavailable in ANY market
This feature would effectively allow the driver to "arm" the valet mode which would typically limit throttle activation and disable boost via the electronically controlled waste-gate, preventing so called valet "abuse".
HTH
Regards
WopOnTour
mbodo's Avatar
mbodo mbodo is offline
My Saabs: 03 9-3SS
For those that are wondering what valet "abuse" is, it's when the valet guy comes back with a HUGE grin on his face, and says "Mister, this is a VERY nice car" ..
mbodo's Avatar
My Saabs: 03 9-3SS
There are a few more, to include
o Onstar failure Contact Service
I had some of that at mile 800. The guy was like "what friggin engine is in this thing?" When I told him it was a fourbanger, he actually called the other valets over to see the car.
Not kidding.
And almost everybody who talks about it thinks the thing cost me 50,000 USD!
Old 14th March 2008
teemplaya teemplaya is offline
My Saabs: 2002 9-3 SE Sungreen Conv.
My SID currently displays CD Error 02.
Has anyone seen that one?
@ 59f the top goes down!
2002 9-3 SE Sungreen Convertible
Old 14th March 2008
The Swedish Bullet The Swedish Bullet is offline
My Saabs: 1996 1900S, 2007 2.0T Anniversary
"Your driving too fast"Is it a typo, or is SID's grammar lacking?
Old 14th March 2008
aerojon's Avatar
aerojon aerojon is offline
Smile
That's one of two error codes given in the manual,possible cause disc dirty or scratched cannot be read,there was no 02.
But if you have a multi disc changer could be disc in slot 2 cannot be read.
hope this is of some help...
Is still running factory oe coils with Hirsch tune..
Old 14th March 2008
CMerriman CMerriman is offline
My Saabs: None
Exclamation
The only quirky SID error I ever received was "Release Park Brake".
The story behind that is pretty simple. I was dropping off my friend after we drank ourselves stupid at a local bar near ESPN headquaters in Bristol. I don't remember it, but I must have engaged the e-brake while in his driveway, but I never disengaged it before backing up onto the street and putting it in drive. Let's just say out of nowhere I heard the "chim", looked at the SID, and was like "O @$#%"...
I released the e-brake, and everything returned to normal.
Moral of the story? Drinking and driving is BAD!
Chris
Old 14th March 2008
BrissySaab's Avatar
BrissySaab BrissySaab is offline
My Saabs: 2004 9-3 Linear Convertible
Ejector Seat Activated
Old 3rd February 2011
JMarkert's Avatar
JMarkert JMarkert is offline
My Saabs: 2004 9-3 linear
Awesome !
JMarkert's Avatar
Sorry, I meant to type SID, rather than CD, my bad but thanks for your reply
aerojon's Avatar
Smile
i think you've posted this in the wrong thread as that answer you quoted was 2 yrs old..and relating to this question by teemplaya"My SID currently displays CD Error 02.
Old 1st August 2012
Mighty Dunk Mighty Dunk is offline
My Saabs: 2001 93
Okay so i just replaced my turbo and keep getting a check engine like and this on my SID does anyone know what it says? i know i need the repair kit
Name:	2012-07-31 22.29.52.jpg
Old 1st August 2012
aerojon's Avatar
Smile
you've posted in the wrong forum here is for MY03 onwards..
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
