heated seat stopped working? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 05-02-10
mick44 mick44 is offline
My Saabs: 96 9000 aero 98 93 cab 2001 95 estate
Question heated seat stopped working?
hi guys, does anybody know if there is an element under the seat that can be repaired or replaced as my drivers seat does not get hot anymore! ive changed the switch and have power but still no heat! any replies would be appreciated, cheers mick.
Old 05-02-10
niskanem's Avatar
niskanem niskanem is offline
My Saabs: 2004 9-5 Aero Combi, 2004 9-3 Arc SS
http://www.thesaabsite.com/9000/seatheatertesting.htm
Old 05-02-10
niskanem's Avatar
http://www.saabnet.com/tsn/faq/heatseat.html
Old 06-02-10
bmacb bmacb is offline
My Saabs: 2 96 9000s and 1 97 9000
Default Heated seat failure - look for broken wire
Seat heater failure is most often caused by a break in the wire that goes through the seat pad in the seat bottom. Peal back the seat bottom cover and look for a scorched spot - usually on the outside rear - caused by the stress of entry/exit. Resolder and you are good to go.
Old 06-02-10
Question
does that mean that the leather that you sit on needs to be peeled all the way off the seat to reveal the sponge underneath???
Old 07-02-10
Default yes
"The seat cover is secured to the seat's wire frame by "hog rings" in a number of places; these are circular rings that need to be spread apart to remove them, and I found that regular and needle nose pliers work best for this. There are two hog rings in the front on the underside of the seat, and five of them on the back of the lower cushion. Then as you peel the cushion back, there are spring fasteners at each lower cushion seam that fasten the seat cover to the wire frame underneath the lower seat cushion"
Old 07-02-10
Jeff325's Avatar
Jeff325 Jeff325 is offline
My Saabs: 1992 9000 S 270K miles 2002 9-5 Linear
After you do what bmacb mentions above, more than likely you will see a burned spot where the wire in bottom seat heater pad opened up. The seat back pad on these seats rarely goes bad.
To repair it take some wire and solder it in between the break in it.
I have done this to a seat heater pad once and it does work. It ended up failing again in the same exact spot, so instead of resoldering it again, I opted for replacing the pad with a brand new one.
