monthly check up.... - SaabCentral Forums
Old 01-02-10
TheDude TheDude is offline
My Saabs: 2001 9-5 Aero 2.3L 4cyl 90k miles
Default monthly check up....
Two questions.
1. I found some oil condensation on a PCV #6 hose coming from the nipple that goes into the cam shaft cover. It is the small hose that branches off and goes to the throttle body. Is this a problem?
2. What do these bushings do in the picture. There are a few of them around they engine and they are kind of loose when you wiggle them. Is this normal? I have P1110 error and I think it may something to do with my brake bossters.
I know these are kind of dumb questions, but it's better than just ignoring them. Thanks all.
Old 01-02-10
ivanwakeup's Avatar
ivanwakeup ivanwakeup is offline
My Saabs: MY00 Aero (272hp/295ftlbs T7suite)
to answer your number one, no not really. that hose gets beat up fast, but dont worry to much about it. Same with mine, and a local indy (worked on saabs for 25 years) said its not a big deal. although i wish i could say more about its function
One thing about deer: They have good vision.
One thing about me: I'm better at hiding than they are at vision.
Old 01-02-10
saabneunfunf saabneunfunf is offline
My Saabs: 9-5 2.0 lpt stage 1 1999
Usually some sort of one way valve in an engine vent system so loose is good
Old 02-02-10
thanks for the help.
Old 02-02-10
toxicavenger's Avatar
toxicavenger toxicavenger is offline
My Saabs: 2006 9-5 Sedan, 2006 Sportcombi
Originally Posted by TheDude View Post
Two questions.
Actually this picture is of the bushing that holds the vaccum lines for your brake booster into the intake manifold/brake booster and booster solonoid. So make sure that you can't pull the hard plastic hose out of them (don't pull hard just a little tug) because if you can the you DO have a vaccum leak to your brake booster. Next step would be ordering some news up. Good luck.
Old 02-02-10
Oh and none of the questions you asked were dumb. It would have been dumb to not ask them.
