Drain plug question (cont from super tight) - SaabCentral Forums
Old 16-01-10
suya suya is offline
My Saabs: 2003 saab 9-5 linear turbo
Default Drain plug question (cont from super tight)
So I bought the "damaged bolt removal kit".. but it didnt really work... so I had to drill a hole till it was close to the point well I actually can literally take them off from the oil pan. so the plug is off, FINALLY
But here's the problem, AGAIN.
I went to every auto part stores to find the saab 9-5 drain plug, but I couldnt find one in any of them(yes this town SUCKS). Real f-ed up situation. I guess that GM backing up caused a lot of pain in saab parts. Is there equivalent plug bolt that I can use for my 9-5? I need it soon otherwise I will be bus.ing. Will be pain in the a-- in this weather.
Old 16-01-10
Breau's Avatar
Breau Breau is offline
My Saabs: 2000 9-5 Aero Wagon HOT
Thread size is m14-1.5, doesn't matter what the head size is.
Old 17-01-10
ivanwakeup's Avatar
ivanwakeup ivanwakeup is offline
My Saabs: MY00 Aero (272hp/295ftlbs T7suite)
I just went and got an identical bolt from a hardware store. easy to find, just know the thread size on it (i don't remember the measurement), and you can get it from anywhere really.
I definitely reccommend getting a LARGER head with the bolt. look for something around 16-17mm. it will be a whole lot easier to get off.
oh and i should mention, the original bolt thats on there is actually 1/2 inch. not 13mm. that equates to something around 12.6-12.7 mm i believe, but if its already in bad shape, it could cause a problem trying to get it off.
i cant believe that bolt remover kit didnt work! my bolt was very tight, i cant even imagine how bad yours mustve been...
One thing about deer: They have good vision.
One thing about me: I'm better at hiding than they are at vision.
Old 17-01-10
tell me about it. it's like freaking welded to the oil pan. is it even possible that the bolt might've melt a little and when the engine cooled down and self welded to the oil pan? if that's so...... I will have to take down the oil pan and check if there's any damages
Old 17-01-10
ivanwakeup's Avatar
i sincerely doubt it. i don't really know how it could get even NEAR that hot down there.
if anything, the copper washer may have somehow stuck, but again i don't know how it could be possible that anything would melt to it. I dont know what temp you need to weld, but i know its VERY high. probably something around 2000-5000 degrees, if not more.
Old 17-01-10
ya that's what i thought too. well it off now. and new bolt with BIG head is now sitting in. Im thinking to buy that fumoto drain plug. has anyone used it before? it seems cool, but it might stick out little longer than bolt types... hope that doesn't cause any problems.
Old 17-01-10
dlague dlague is offline
My Saabs: 2003 95 Aero, 2001 95 Aero
I buy 2 to 3 drainplugs at a time from eeuroports along with copper washers.
The best wrench is 1/2 box end wrench. I also us a 1/2 impact socket on an electric impact wrench. MAKE SURE THE WRENCH IS SET TO COUNTER CLOCKWISE!!
I tighten by hand.
Old 17-01-10
hiros's Avatar
hiros hiros is offline
My Saabs: Saab 95 Aero M00
[QUOTE I tighten by hand.[/QUOTE]
A very good advice for all fasteners. Make sure that the thread feed in properly before putting a wrench or spanner to it.
A vice grip is also a useful tool to have to remove a worned out drain plug head.
Old 17-01-10
so ya my oil change job took me freaking 2hrs, some for buying stuff tho 10min job becomine 2hr job isn't so fun. but seeing that my 9-5 is now going smoother than ever, my soar arm and freaking tiredness is worth it. thx guys. now I have almost every tool to have fun with my saab. somewhat happy
Old 18-01-10
I love my saab 95 I love my saab 95 is offline
My Saabs: 9 5 se
I hope you put a new copper washer on with the new bolt or you can look forward to all that fun next oil change
Old 18-01-10
ivanwakeup's Avatar
dont worry, happens to me all the time. a 2hr job seems to turn into an ALL DAY job far too often...
Old 19-01-10
saabneunfunf saabneunfunf is offline
My Saabs: 9-5 2.0 lpt stage 1 1999
The stock bolt is actually metric but the best fit is 1/2". I ended up using a pipe wrench with a long pipe over the handle to crack the bolt.
Torque it up to the correct figure afterwards and you shouldn't have a further problem (new washer of course).
Old 19-01-10
cse_20's Avatar
cse_20 cse_20 is offline
My Saabs: 2006 9-5 2.3T HOT w\Sport Package
I did and I love it.
It does not stick out that much further, and with a calculated 1/4 turn more you can get the actuator (to open the drain) , up and out of the way from anything remotely coming close to the bottom sump casting.
Regards,
