Rotten egg smell. - SaabCentral Forums
Old 12th January 2010
f1rlz's Avatar
f1rlz f1rlz is offline
My Saabs: 2003 93 Linear Sedan
Question Rotten egg smell.
It's been very cold here lately and I noticed the smell after I start my Saab, it goes away after the engine warms up.
Any ideas? Thanks.
xp3's Avatar
xp3 xp3 is offline
My Saabs: '03 Saab 9-3 2.0t
Any ideas? Thanks.
It might be a failing catalytic converter. However this is a result of something else going bad. Check for misfiring or blown head gasket.
Current mods: 14t swap w/ JZW tune, GS Strut Brace, Aero front lip, 9-5 Aero turbine wheels,
(check out my for-sale-thread)
Coming soon: downpipe/exhaust, Aero body kit
My other SAAB is a car.
stamonkey's Avatar
stamonkey stamonkey is offline
My Saabs: 1988 C900 SPG
Its probably excess sulfur from your fuel that your catalytic converter doesn't catch until it gets a chance to warm up. Are you burning the good stuff?
f1rlz's Avatar
How do I check for blown head gasket?
JonV JonV is offline
Saabista
My Saabs: 03 SE 5 Spd
The Cat is failing. No CEL?
f1rlz's Avatar
Lately I have been buying 10% ethanol gas. I bought some good gas (100%) today....
xp3's Avatar
xp3 xp3 is offline
Any other symptoms?
rough idle, shaking/rattling, white smoke coming from exhaust, oil/coolant leaks?
f1rlz's Avatar
No CEL at all. I thought CAT's don't fail in Saabs...
f1rlz's Avatar
No white smoke. It is idling a little rougher it seems.
f1rlz's Avatar
I just remembered that my coolant level was low a few weeks ago it wasn't below 32 at the time, I topped it off and the "coolant level low" warning disappeared from the SID.
Let's assume the worst, if the head gasket is blown, what kind of repair cost am I looking at?
Thanks a lot!!
Old 13th January 2010
stamonkey's Avatar
Thanks a lot!!
A head gasket would be pricey (probably like $1k or so) but a blown head gasket won't give you the symptoms you describe. Does you car overheat? Do you have a milky substance in your overflow tank? Do you have a milky substance in your oil? Any smoke? These are signs of a head gasket failure.
I would put my money on poor fuel, an O2 sensor on its way out, or at worst a failing catalytic converter. The sulfur smell is a byproduct from the combustion cycle.
Saabista
If your not blowing white Smoke, smelling the Sweet Coolant smell and your Oil is clean it's simply not your headgasket.
Saabista
That has nothing to do with it.
JBob's Avatar
JBob JBob is offline
My Saabs: 2003 9-3SS 2.0t Vector, Steel Grey (OOW)
Not necessarily. The rotten egg smell is caused when there is insufficient oxygen in the cat to reduce the sulphur in the exhaust gases - the result is hydrogen sulphide.
This can be caused by many things - a failing (plugged) cat, a failed air pump, over fuelling, excessively hot cat or cold cat. For example, you can often smell it when cars have to wade through deep water, dowsing the hot cat in cold water...
Strangely, the rotten egg smell can mean your cat is failing, or that it is working! This smell is common on some cars (1990's Subarus seem particularly prone to it), probably due to less than perfect fuelling. New cars are also often prone to it too.
The CEL will only illuminate if the downstream oxygen sensor signal conflicts with the upstream one.
If it only occurs when cold (especially if the car hasn't been used much recently) then I wouldn't worry about it. Take it for a long run and get that cat nice and warm! I'd only be concerned if it failed an emissions test.
Piper of Rose Piper of Rose is offline
My Saabs: 2004 9-3 Linear
I think its caused by GM
Diggs's Avatar
Diggs Diggs is offline
My Saabs: 2003 9³SS Linear
Ha! Nice one.
I've had on again off again rotten egg smell since I bought the car new. No blown head gaskets or failed cats here.
I'm not saying it's a coilpack.....but it's a coilpack.
stamonkey's Avatar
Yes it does, poor quality fuel with a higher sulfur content allows for more hydrogen sulfide to be produced.
Unless Jon, your talking about the 10% ethanol blend, then that wouldn't matter.
Saabista
Yes I'm talking the 10%..... but this sounds like more Than a "one Tank" of bad gas Issue..... just get an emissions test and see what the result is. If it were running rich you smell the gas....
jlrdrony's Avatar
jlrdrony jlrdrony is offline
The rotten egg smell is caused due to there is water pollution in the wiper tank.
Actions to be taken:
-Vacuum the water wiper tank with a hose. clean it as much as possible.
-fill up top the wiper tank with a new water.
-replace the air cabin filter with a new one.
-clean the firewall area and the drain grommet.
f1rlz's Avatar
There is no emissions test in Oklahoma.
I checked my oil, no water in it. I checked my coolant- no oil in it, just a little low. Is that normal, coolant evaporates over time?
I recently put a new air filter and cabin air filter in, so I think those are ok.
No white smoke at all. Engine is not overheating at all.
I always buy 91 octane gas at Shell stations (only in the last month I have been buying 91 octane with 10% ethanol at other Shell stattion since I moved) but I will go out of my way to buy 100% gas again.
I didn't smell it today....
Thanks for all the replies.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
