Drop Links - How to replace? - SaabCentral Forums
Old 11-01-10
boolay boolay is offline
My Saabs: 9-5 Aero 2003
Default Drop Links - How to replace?
In an atempt to cure my groaning and knocking front end, I'm wanting to replace my front Drop Links/Stabilser Bars. I had the ARB Bushes replaced last week which didn't solve the problem, and as the Drop links a relatively cheap, I'm hoping I can replace them myself to save some cost.
Does anyone have/know of a guide to changing these?
Many thanks
Old 11-01-10
helmetvonthrob helmetvonthrob is offline
My Saabs: = 2003 Aero x2 =
Easy, parts are available from GSF @ about a tenner each.
Jack up, wheel off, 18 or 19mm spanners undo both ends, ping them off, put the new ones on and lever the ARB with a jack handle to get the top of the drop links into the ARB holes.
Old 12-01-10
Ah, that does sound easy. Thanks very much for your help
Old 12-01-10
hiros's Avatar
hiros hiros is offline
My Saabs: Saab 95 Aero M00
Easier to get it done with the front end up on jack stand and both wheels of the ground.
This will relieve the pressure on the ARB making it much easier to replace the drop links.
Old 12-01-10
MacNoob's Avatar
MacNoob MacNoob is offline
My Saabs: 01 9-5 Wagon (RIP); 05 9-5 Aero (gone)
Yes, either both wheels ON the ground or both wheels off - as long as they are even there will be no pressure on the end links.
Old 12-01-10
MI-Roger MI-Roger is offline
My Saabs: 2008 9-5 Aero Sedan, 2006 9-3SC 2.0T
Default Long profile wrenches
IIRC the factory drop links require a 15mm and a 17mm open end wrench to hold the bolt flats and loosen the nuts. The replacement bars may use different sizes.
The long profile wrenches give you extra oomph to break the nuts loose.
Old 12-01-10
I thought they were bigger than that, 17/18?? - i do recall that my nuts were bigger going on than coming off??
Old 12-01-10
hiros's Avatar
I believe different aftermarket supplier may provide different size of fasteners. Anyway have a full set of open wrench.
I bought an aftermarket tie rod end from US and the bolt size is 3/4" while the existing one is metric.
That said, fitment and functional wise there are no issues.
Old 13-01-10
3/4" and 19mm are to all intents the same as are 1/2" and 13mm.
I do remember the Nylocs being one size taking off and another going on; 19 vs 18 from memory.
Old 14-01-10
rcase13 rcase13 is offline
My Saabs: 2003 9-5 SportWagon Linear
When I go over speed bumps (not fast) I get some noise from the front end. What other than these can cause suspension noise? These are simple so I will start with these.
Old 15-01-10
Apparently the subframe bushes can also cause creaking and groaning. That is going to be the next big hit for me if I can get part no.s etc.
