| Saab 9-5 Workshop Saab 9-5 Workshop (1997 to 2010) Technical Forum |
Is possible at all?
Basically I tried to replace batteries.. and didn't work out very well. The pins from new batteries(http://store.batteryspecialists.com/cr17335seft.html) did not fit.. and I tried to make holes larger Anyway, I was wondering how difficult is to get a new module and replace it? Can I do it by myself? Or I have to go to a dealer for some "magic" ? Is the theft module tight to my car only or I can use another one? May be a newer one(does it worth?)? Just found this item (http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123) on ebay from 9-3, will this fit ? Thank you in advance. PS: sorry for too many question marks Last edited by octix; 10-01-10 at 08:50 PM. Reason: added one more question |
| Sponsored Links | ||
Advertisement | ||
I have no answers to your questions, just more questions. How were the pins on your OEM batteries attached? Could you have desoldered and reused them?
Probably I could. I even thought about it... however doing that would definitely heat battery too.. so I wasn't sure if that's the way to go... I have no experience with soldering..
A quick search on this forum will revel a thread with nearly 500 posts regarding correcting the "Service Theft Alarm" problem. Solutions include:
BBA-Reman might be able to help: http://www.bba-reman.com/catalogue/D...edProduct=1406
or http://cgi.ebay.com/ebaymotors/Saab-...ht_2063wt_1167
2003 Saab 9-5 Aero Sport Wagon >>> My other home: http://saabworld.net/forum.php 2.3T HO B235R Manual 132,500 miles http://youtu.be/TZDGk5NXdh4 |
That is Brilliant, I'm going to be giving them a go!
Cheers photousa!
Mods so far, Poly gearbox mount, poly anti roll bar bushes, Koni FSD shocks, Quaife LSD, Silicon vacuum hoses, Forge dump valve, braided brake hoses |
i received the service theft alarm on sid and removed the siren to discover my 2003 95 has the 'non-servicable' unit. used a dremel tool to cut into the box, ordered batteries from tselectronic.com and put everything back together this morning.
issues noted - cutting into plastic box presents obvious issues with reseating/resealing. during manufacture a protective coating was applied to circuit board and this might cause new installations to the board not work. the unit will be put back in the car this afternoon once the adhesive cures. old batteries were a hair off 3 volts on the meter so hopefully this was enough to trigger the alarm failure warning. if not i butchered the $297 part for nothing. questions - do other cars suffer from this battery issue? who builds a box that contains a time limited device and seal the box? |
Here is a link on ebay. Anyone else try these guys?
http://cgi.ebay.com/ebaymotors/SAAB-...Q5fAccessories |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
