9-5 thermostat chang need instuctions - SaabCentral Forums
Old 6th January 2010
2000saab95's Avatar
2000saab95 2000saab95 is offline
My Saabs: 2000 Saab 9-5 Aero
Default 9-5 thermostat chang need instuctions
NEed INstruction I have a 2000 9-5 aero that I need a thermostat change walk thru is there any around .
helmetvonthrob helmetvonthrob is offline
My Saabs: 2007 9-5 Aero HOT Anniversary
Check the FAQs
Old 7th January 2010
2000saab95's Avatar
Default faq not working
faq isnt working
MacNoob's Avatar
MacNoob MacNoob is offline
My Saabs: 01 9-5 Wagon (RIP); 05 9-5 Aero (gone)
working fine - here is the direct link
http://www.saabcentral.com/forums/sh...71#post1531771
ClemsonScout's Avatar
ClemsonScout ClemsonScout is offline
My Saabs: '02 9-5 Aero 5-speed
http://www.twinsaabs.com/9-5_repair/...ps=2&nointro=1
Here's another one.
I went with a Super Stant and haven't had a problem. Most others uses a Whaler brand IIRC, but a few have had them die.
2002 Saab 9-5 Aero, 5-speed, Steel Grey, Remus exhaust, 3" DP, Intake, Stg 3, 2004/2005 Front end.
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Originally Posted by 2000saab95 View Post
faq isnt working
hacker-pschorr hacker-pschorr is offline
My Saabs: 1999 9-5
Nice timing, changing mine on Saturday. All of a sudden the temp gauge doesn't go past 1/4 and the heat out of the vent is lukewarm.
Old 11th January 2010
2000saab95's Avatar
Default 2.0 and 2.3
will it be the same for the 2.3 as the 2.0. I see in the pictures of the best one that it says 2.0
rcase13 rcase13 is offline
My Saabs: 2003 9-5 SportWagon Linear
Must be that time of year for these to fail. I have the same problem. I just had the coolant flushed 9000 miles ago. Any reason I can't drain just a little to change the t-stat and put it back in when done?
mt.aero's Avatar
mt.aero mt.aero is offline
My Saabs: '02 9 Aero, '89 900S
Same deal.
Its not necessarily the time of year that they fail, but you finally notice its failed since it so cold out. And you can def just drain some out and reuse it. Just make sure you are using a nice clean pan to drain the coolant into.
2000saab95's Avatar
Default thermo
This one says nothing of drainging coolant that is why i was wondering if it was different for the 2.0
looking at the WIS instructions you will need to drain some of the fluid or you are going to get wet!
Also the WIS states to use Vasoline on the rubber o-ring for the thermostat. Is this correct? I use the regular household Vasoline for this? Funny I always thought Vasoline was bad for rubber. I guess i was wrong?
mt.aero's Avatar
Yah, thats odd they say to use vasoline. I was also under the impression that vasoline was bad for rubber. (stuff you learn in sex-ed class ) Personally, I use a synthetic grease on my o-rings. (that sounds dirty now that I mentioned sex-ed class )
Oh god that is just too funny. I think that is where I recall hearing that also... i was getting my rubbers confused... it's not auto rubber it's rubbers of the latex variety that is bad. So we are propably good to use it on the automotive rubber... LOL well you can't say I didn't retain some of what I learned in high school!
My Saabs: 1999 9-5
I have one of these:
http://www.amazon.com/Mityvac-7400-F.../dp/B000IHI80O
I sucked all the fluid out of the reservoir and the lower hose that goes to the engine. While it was sucking, I squeezed the upper hose until it sounded like there was no more fluid in that line. After doing this, I lost almost no coolant after disconnecting the upper hose and popping the thermostat off.
Trying to burp an engine with an ambient temp of 9 isn't easy. I drove the car around for quite a while, then idled in the garage for what seamed like an eternity. The temp gauge never went above half and the fans never came on once.
mt.aero's Avatar
Hmmmm, it sounds like the thermostat might be jammed open. I cant think of what else would cause this since air in the system would likely result in overheating. Its possible you got a faulty unit or something came loose in the system and got stuck in the stat. I would take it out and put it in a pot of water on the stove with a thermometer to record what temp it opens at.
Interesting that this item apparently sells along with a Wii Fit Resort!
My Saabs: 1999 9-5
Always test before installation, problem is the thermometer I could find maxed out at 190 (could not find the digital). The new thermostat did not start to open until just past 190. The old one was wide open by then, started to open around 160!!
This is not abnormal in this weather. My Audi can idle forever before the fans kick on. I'm not one that normally idles to warm up, but some issues in the past with my Audi I've been somewhat forced to observe this
mt.aero's Avatar
Assuming you have the 89C 'stat it sounds like its operating properly. Thats what I have and no problems getting to normal operating temp and full heat in a matter of minutes even in the -20F temps we have been having. I may have been confused by your other post though...... the temp gauge does make it half way?
My Saabs: 1999 9-5
Yes, climbs quite fast (like yours) to the "9 o'clock" position half way between it's resting position and critical mass.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
