Reverse Lock-Out Question. - SaabCentral Forums
Go Back   SaabCentral Forums > Saab C900, 1979-1993 & '94 Convertible (C=classic) > C900 Performance, Mods & Tuning
C900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic 900 (C900)
Old 4th January 2010
DustinS's Avatar
DustinS DustinS is offline
My Saabs: '02 9-5 Aero/3 c900T/1 c900 8v
Garage
Default Reverse Lock-Out Question.
Short Shifter DIY
I planed on doing this, but i don't have reverse lockout in the first place.(plastic case was broken/worn down before i got it) so could i leave reverse lockout out of it?
...with some hack welding it should be possible...
white65's Avatar
white65 white65 is offline
My Saabs: SPGCLONE
Default S/S Mod - Another method
I used these instructions from this site.
http://www.ricdidonato.com/Downtime/...rtShifter.html
Better pics and easier mod. You can adapt method to use the plastic ball.
DustinS's Avatar
Garage
thanks. he is doing a 45% reduction. i may try it, it is in the second half of the link i posted
but i was going to cut it seeing as i do not have a second kit, nor a junk yard around that has any 900's(which really sucks). i was just asking if i could leave the reverse lock-out part off seeing as mine doesn't work anyway.
Old 5th January 2010
KurBads's Avatar
KurBads KurBads is offline
My Saabs: `68 96V4; `69 Sonett V4; 2Xc900 airflow
I could sell you a custom made short-shifter that is plug`n`play (direct replacement) product. Easy installation in ~ 1/2 hour, retained lock-out functionality.
`89 c900 8v; `93 c900 16T (x-LPT) airflow
DustinS's Avatar
Garage
Thanks for the offer, but i think i am going to pass for right now.
What would you guys say would be a good reduction? I am thinking 30-45% but that would be around 3 inches off the bottom. and at only 13" stock, that makes it quite short. how tall are most short shifters from the center console to the knob?
Old 6th January 2010
philjohnhb's Avatar
philjohnhb philjohnhb is offline
My Saabs: Black T16 'Carlsson' vert, 9-3 Aero Vert
If you are just going to shorten the lever, which is what I have done on my 'vert, you still need to sort out the reverse lock mechanism. Why? because reverse lock out is not all that the sprung pin on the bottom of the lever does. It also aligns the lever for all the other gears, without the pin the lever flops about all over the place.
Check my project thread for an explanation and diagram of how to do it successfully. It's on page 6.
If, on the other hand you are going too move the fulcrum up then I would recommend no more than an inch, I did this on another car and it was more than enough.
Phil H-B
Originally Posted by Jim Mesthene
Other pieces of your car could fall off, if not bolted on.
DustinS's Avatar
Garage
thanks i'll check it out
how much did you shorten it?
Old 7th January 2010
Greyspg's Avatar
Greyspg Greyspg is offline
My Saabs: 1988 SPG (t5, hy35), 2003 9-5 Aero
take everything apart. cut 2.5 inches of the bottom, redrill the hole for the pin and cut the top of the wire off for the reverse lock out and re bend it to work. done. 30 min with powertools.
Greyspg's Avatar
sums up the web page. haha
KurBads's Avatar
well, that won`t be a short-throw shifter but just and only shortened/lowered shaft shifter - meaning you`ll just be grabing it an inch lower as original. To have short throw shifter one needs to change the length between swing bearing and the lower ball. and to that one needs to raise upwards the seating position of the swing bearing (being it original plastic or custom made (as in mine) shaft/ball/bearing+housing). Only than you`ll get shorter throw and firmer action.
in addition, if one cuts off from the bottom of the shawt it needs also to drill that exact length into the shavt where lockout pin goes - to allow the spring and the pin to go in as in original - there`s a step for the spring to sit.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
