SID went black - SaabCentral Forums
Old 28-12-09
Indrek Indrek is offline
My Saabs: Saab 9-5 Estate 2002
Unhappy SID went black
Hi!
Yesterday starting to drive home after long hollyday my Saab 9-5 Sid display went black. Can't see anything. When I started my car everything was working propperly. I stopped for a moment and then SID went black. The buttons work that much I know (my washer fluid wnet low and the info display sign lighted in dashboard and when I pressed clear button it went off). Is it repairable? Is there fuse for SID? Before that SID worked excellently, no pixels missing. Is it possible that SID dies instantly with out warning (read missing pixels)?
Old 28-12-09
And one more qestion. My car is from 2002, is it possible to fit SID from an later car?
Old 28-12-09
SaabScott's Avatar
SaabScott SaabScott is offline
My Saabs: 1993 900S
It is not ... they changed them and it will not work.
President,
The Saab Club of Canada
www.SaabClub.ca
1993 900S
Old 28-12-09
valbowski1980's Avatar
valbowski1980 valbowski1980 is offline
My Saabs: 2005 9⁵ Aero
Garage
So the whole thing is black? Have you checked the bulbs? You can have your SID rebuilt.... BBA are great but for the love of god don't use Kramer!
There is a "replacement for displacement".... It's called "forced induction".
Old 28-12-09
Yes thge hole thing is black. I haven't checked the bulbs. Does the bulbs affect SID so that you can't read anythin from the display? I've got nothing there. an't see temperature, clock, any radio or track information and other stuff.
Old 28-12-09
Garage
If the bulbs are gone you won't be able to see anything at all. It is possible that the ribbon has detarched as well.
Old 28-12-09
ski ski is offline
My Saabs: 02 95 aero
this may be a stupid question, but did you hit the night panel button? my brother did this accidentally the other day and was like "what happened?!?!?!"
Obviously the night panel function is back to off once the car is restarted.
Old 29-12-09
No I didn't hit the nightpanel button, because then all the dashboard would be black. Except the speed indicator up to 140 km/h. This was the first thing I checked.
Old 30-12-09
Found out that the fuse was burned out. Changed the fuse and all works perfectly.
Old 30-05-11
Saabtopia Saabtopia is offline
My Saabs: 2003 9-5 Linear
Fuse #8 worked for me. Now I just need to get the rest of the pxels back!
Old 27-06-11
OK, well the fuse change did not work, since the fule blew a gain in a few days, and I've blown out one more in a short period of time.
Old 27-06-11
Rarelibra's Avatar
Rarelibra Rarelibra is offline
My Saabs: 2004 9⁵Arc Maptun stage IV
Garage
This was going to be my suggestion - the 10amp fuse.
Careful with a wire located near your throttle - if you meddle with it too much, it causes this fuse to blow. You will also lose your turn signal noise, if you didn't notice... ask me how I know.
Old 27-06-11
Sparky's 9-5 3t's Avatar
Sparky's 9-5 3t Sparky's 9-5 3t is offline
My Saabs: "Freja"- '03 9-5 V6 Arc by Rabbit
I HATE the turn signal noise. Probably the only thing on my car that annoys the sh*t outta me.
--T7 Suited V6 by Rabbit--Taliaferro K&N assembly--Relay 666--Rear fog light mod--6k HID headlamps--18" SS wheels--245/40/18 Yokohama Advans--Blacked-out front grill--
Old 28-06-11
My problem was the lights under the rear doors. They fell out from their sockets and there came short circuit when they touched the car body. Removed them and no short circuit and blowing fuses anymore
Old 29-06-11
That was one of the questions I had. Which other electical items are connected to fuse #8? The fuse list only shows the SID.
I'll check the door bottom lights.
