running lean!!? - SaabCentral Forums
Old 26-12-09
PeteM PeteM is offline
My Saabs: 94 900 turbo vert and a 02' 9-3 se HOT
Exclamation running lean!!?
hey everyone, merry christmas. i have a custome made downpipe thats catless with a stock tune, and i herd that the car is running lean and i would like to know if it is.. how lean is it running and how bad it is for the engine
Old 26-12-09
'97 Saab SE Turbo's Avatar
'97 Saab SE Turbo '97 Saab SE Turbo is online now
My Saabs: Black on black '97 Saab 3-door SE Turbo
If you think that your engine is running lean, you need to install a monitoring sytem like the Innovate LM2 that will monitor A/F ratio. It requires a new bung for the sensor, and it's not cheap, but it will tell you what your A/F ratio is... Ron
Old 26-12-09
AZ Saab AZ Saab is offline
My Saabs: '06 SportCombi,02 Aero,03 Aero
With just a dp the car shouldn't be running lean. Do you hear sounds of detonation? Running lean isn't good. I recently replaced an engine after the #4 piston cooked itself. A few weeks ago I installed a wideband air/fuel gauge to monitor the new motor. It's cheap insurance to monitor your motor and not too bad to install. Good luck.
Old 26-12-09
i dont notice any detination, how much are widebands? and where can i get em?
Old 27-12-09
John Z Williams's Avatar
John Z Williams John Z Williams is offline
Vendor
My Saabs: b234-E85-10.59@138.57mph
You can also get on a dyno and they can check the a/f at the same time for about 65 bucks. You can buy a cheap scan tool and have at least some narrow band a/f data, should tell you if its really bad, but the dyno with a/f would be the cheapest best cost effective way to know for sure.
If it is lean, its usually because of a weak fuel pump, there is enough fuel injector to adjust for no cat easily.
good luck,
John
10.59@138.57mph Fastest Saab in America!
Old 27-12-09
i would also like to mention that ive had the downpipe on the car for around 4 months and so far ive had no problems what so ever
