'00 V6 Afterheater doesn't work - SaabCentral Forums
Old 20-12-09
gb3347's Avatar
gb3347 gb3347 is offline
My Saabs: 00 9-5 SE Wagon
Default '00 V6 Afterheater doesn't work
Hi all,
A few nights ago I tried to use the afterheater function on my 2000 9-5 SE V6 and it didn't work. The coolant was warm enough (I had driven the car almost 1 hour), the ignition was off for less than a minute, I held AUTO for a few seconds but nothing. BTW, this is the 1st time I tried it since owning the car, so I doubt it ever worked.
I read that it might need to be activated by Tech 2 first, but the only one in my area charges $50 and I don't need anything else done via the tool, so it's not worth it. Is there any other way to activate the electrical cooling pump in order to have this feature? Thanks
Old 20-12-09
gghh gghh is offline
My Saabs: BMW 530D Touring xDrive
Did you replace the SID? It needs to be coded to use the spare heater, tech2 is the only option.
Old 20-12-09
baco99's Avatar
baco99 baco99 is offline
My Saabs: 2008 Saab 9-5 Aero Sedan
spare heater feature is worth 50 bucks, IMO. we use it all the time. i don't understand why all cars don't have it!!!!
2008 Acura MDX
1981 Mercedes 380SLC
Old 20-12-09
raquettelaker2's Avatar
raquettelaker2 raquettelaker2 is offline
My Saabs: 2004 9-5 Aero, 2001 9-5 SE V6 (sold)
+1. Go get it programmed to work. That's the feature I miss the most after switching from my 2001 SE V6 to my Aero.
Old 20-12-09
gb3347's Avatar
Yes, I replaced the SID as soon as I bought the car. So that's why it doesn't work...
Too bad Tech 2 is the only option, but from what I've heard I guess the feature is worth $50 in itself.
Old 20-12-09
ski ski is offline
My Saabs: 02 95 aero
just because I am not familiar with how the system works, but knew that it existed on the v6. Is there some sort of secondary pump to keep the fluid circulating (and warm) while this after heater is on? You would think if it were really cold outside it would not be effective for very long if there were no seconday pump to circulate the fluid.
Old 20-12-09
Yeah, there's a secondary electric coolant pump. Pretty darn nifty. If it's real cold out it doesn't last all that long, but it sure makes a difference if you're running into the store for 15 minutes. Mmm. Afterheater.
Old 21-12-09
Dropframe Dropframe is offline
My Saabs: 1999 Saab 9-5 SE, V6
I will probably just keep repairing my car forever b/c its the only car I have ever seen with that feature. It's my #1 must have feature on a car now
Old 21-12-09
Mercedes has this also.
