Better fuel mileage by accident - SaabCentral Forums
Old 16th December 2009
jacksaab jacksaab is offline
New Member
My Saabs: 2000 9-5 wagon
Default Better fuel mileage by accident
Engine Management light went on during a trip so although I was apprehensive but none of the other specific indicators were showing problems and the car continued to operate well at highway speeds. When I got home I had gone over 200 miles and had used only about 1/4 tank. I checked what I could and by the time I could scheduled a diagnosis with my mechanic I had gone 545 miles on 3/4 tank of fuel. They discovered the 1/4" (?) hose connecting the Turbo airflow at the front of the engine to the Bypass valve mounted near the firewall had come loose. They said it was only effecting my Turbo-Boost and should not be causing damage. I had the hose replaced but wonder if anyone else has had this happen. If the mechanic is correct why not disconnect the hose again or perhaps put in a "T" fitting that could be plugged to connect the airflow as originally designed or unplugged and capped with a simple filter material to to keep the line clean while safely releasing the pressure (or vacuum) for much better mileage.
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Ok so, lets assume the check engine light was indicating a problem with the car running lean - not enough fuel (upset by the leak) sure you'd save petrol byy ignoring the warning but you may also melt a piston
New Member
Question Lean fuel mix
Thanks for reply. That was my first question to the mechanic...was this indicating fuel too lean or airflow in bypass line not reading correctly. They checked the computer readings and didn't think it was running so lean as to burn a piston. Wouldn't this effect the temperature reading? Still need to know more before I change the original connections.
gghh gghh is offline
My Saabs: BMW 530D Touring xDrive
Leave the connections as designed. Saab would have disconnected the hose from factory if this would improve mileage this much without damage.
New Member
Default Lean fuel mix
I'm inclined to agree. This is my 4th (successive) Saab over the last 20 years. I think these cars have had a lot of thought put into their design.
mnztr mnztr is offline
My Saabs: 2004 9-5 Arc wagon
No lean running would not result in high temp warning as the heat is very localized. At low power output it will probably not be a problem (highway cruise etc.) but at high power output it can destroy the engine pretty fast. It also results in very high NOX emissions.
Old 17th December 2009
New Member
I appreciate this information. I think this is a great car and want to keep it in the best condition I can before my next Saab purchase. Thanks.
SaabScott's Avatar
SaabScott SaabScott is offline
My Saabs: 2006 9-7X 5.3i
That hose is one of the worst in terms of needing to be replaced regularly.
The amount of heat it is exposed to is crazy.
You also have to be careful that the replacement hose is high quality ... we only use Saab turbo vac hose for that one.
President,
The Saab Club of Canada
2006 9-7X 5.3i
New Member
Default Turbo Vac Hose
The new hose was very thick-walled yet appeared quite flexible. We lost our Certified Saab Repair Shop here in Sarasota recently and for the last few years have been going to a great European Performance Mechanic who is very thorough and appreciates the Saab design. Wish he had Saab Certification but he does research my problems carefully. Thanks again.
Old 25th March 2014
brake16 brake16 is offline
My Saabs: 2005 9-5 Arc
Does anybody know what this hose is called? I need to replace mine, and I want to make sure I get the right piece. Eeuroparts has 1-meter silicone vacuum hose (3.5mm id, 2mm wall). Would this work?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
