Engine mount replacement - SaabCentral Forums
Old 2nd December 2009
SaabNineThree SaabNineThree is offline
Banned
My Saabs: 2001 9-5 Aero
Default Engine mount replacement
Does anyone have a link to write up so i can try this on my own? also does anyone know a rought retail price in USD or CDN of the upper arm?
Thanks.
SaabScott's Avatar
SaabScott SaabScott is offline
My Saabs: 2006 9-7X 5.3i
There are 2 engine mounts, 1 transmission mount, and a torque rod for the tranny.
Which do you want to replace?
Which transmission do you have?
President,
The Saab Club of Canada
2006 9-7X 5.3i
Banned
Well basicly the car is making a clunk noise when gas is applied at a high rate so i already replaced the bottom torque mount with the GS blue mount and i replaced the tranny mount under the battery with an OEM mount so i have 2 engine mounts left the top and the rear one..
SaabScott's Avatar
How many km's on the car?
I've seen a lot of 9-5's go through the shop, some really high mileage ones and while I keep both of those mounts on the shelf, I can't recall ever having replaced any.
I will be happy to get you some Canadian pricing tomorrow.
President,
2006 9-7X 5.3i
Banned
159,000 now yeah one of them went if you could get me the price of the upper and lower one if you guys do cash that would also be great.
Old 3rd December 2009
Banned
i would be most likley willing to buy the top one right away if the price is lower then the dealers.. because im located in the GTA
Old 7th December 2009
Don1 Don1 is offline
My Saabs: 1999 Saab 9-5 SE 4cyl 2.3L
Default Engine mounts
I too need to replace my engine mounts. I have over 145,000 miles on my 1999 9-5. Can anyone advise how many mounts there are and where is the best place to buy them? Also, any DIY diagrams out there? I am not doing it myself but my indy isnt too familiar with Saabs so I just want to be prepared just in case. Thanks.
justin.graeff justin.graeff is offline
My Saabs: 2000 9-5 Aero
I took my 9-5 in a few months back for an acceleration issue, and it turned out that the lower mount had gone bad which took the intercooler hose with it. I could tell there was a bad mount because when you accelerated, the car would clunk. They replaced the hose and mount and everything is all better. I had 148k on mine when they the work. I would suggest doing it yourself as the mount was extremely expensive and so was work.
AIM: hyperspaztik49
Skype: Justin.Graeff
MI-Roger MI-Roger is offline
My Saabs: '08 9-5 Aero, '06 9-3SC, '00 Viggen
Default Potentially 5 mounts on the 1999 cars
The 2000 and later have 4 engine mounts:
  1. Hydraulic mount under the large aluminum yoke
  2. Rubber-in-shear mount under the battery tray
  3. Tourque rod mount between trannsmisison and front cross frame
  4. Hydraulic mount on the back side of the engine, close to the firewall
The 1998 and maybe 1999 cars had a 5th mount, an additional torque rod between the tranny and the rear cross frame of the engine cradle. This mount was later discovered to serve no real purpose and was eliminated, although portions of the mounting bracket are still present on some pre-2002 cars.
See attached link for parts list and diagram of mounts, courtesy of www.eEuroparts.com
http://www.eeuroparts.com/Main/PartsResults.aspx
Replacing mounts #1 thru #3 is easy, #4 is a bear and few have replaced this one. Since #5 is unnecessary, why bother with it?
I did #1 thru #3 only on my 2000. My torque rod was attached to the front cross member with a long thru bolt torqued to 80 ft-lbs. This required purchase of a long profile 18mm wrench to break it free as there is no room for a breaker bar.
Banned
Yeah im thinking that im having the same issue as you it might be the lower one im going to get it looked at because it clunks like crazy every time i put the gas on and it feels like i lost power...
Ivan's Avatar
Ivan Ivan is offline
My Saabs: MCY 5dr Viggen/08 9-3 Aero/9-5s
I'm pretty sure the rear mount is not hydraulic.
Old 8th December 2009
Banned
Yeah im going to speak to a few machnics and try and get the part, is the bottom one hard to change i usualy like to DIY but if this invloves getting the car up high and in this temperatue i rather pay to have it done.
stipud's Avatar
stipud stipud is offline
My Saabs: 1999 9-5 2.3lpt Auto Nordic Stg. 3+
Garage
I did all the mounts in my garage and found it easy. The left and right mounts are a snap, you just need a jack to hold the engine up while you replace them. The torque rods underneath take about 5 minutes each from the bottom (I replaced both, if only to reduce wear and tear on the front mount). The rear one took the longest but it wasn't all too complicated to do through the top of the engine when the car was on the ground... maybe spent an hour or two on it. I think it only took me about 4 hours to do every last mount.
I lubricated all the accessible screws with penetrating fluid several times before I took it apart, so it was pretty easy.
Tuning:
Stereo:
Looks very similar to the right upper hydraulic mount to me, without the can of course. But I could be wrong. The limiter strap makes me believe this is not a solid block of rubber.
Does anyone know if this mount contains oil also?
Old 9th December 2009
Banned
Okay i found out it was the upper engine mount that was toast, thanks to SaabScott and Aktive motors Christian ( owner ) pressed the brake and the gas at the same time relasing the clutch slowly and all i saw the the right side of the engine elevate a good 3 inches above where the mount was suppose to stop. That solves the issue of hearing a clunk during acceleraton and shifting, i got the part and i am going to put it in on saturday.
Thanks agian.
Old 11th December 2009
Banned
Okay i installed it the car feels like new. the clunk is gone.
aslan's Avatar
aslan aslan is offline
My Saabs: 9-5 Aero
ive been to active motors, pretty good place; but too far
all the way in mississauga;
how much did it cost you ?
Banned
Yeah it broders oakville and mississauga, i payed 200 for the part i tryed to do it myself but i broke two sockets so i went to them to do it, impact wrenches FTW.
Old 3rd January 2010
dlague dlague is offline
My Saabs: 2003 95 Aero, 2001 95 Aero, 2000 Aero 5d
I did the upper mount on my wife's 95 Aero yesterday. It was so easy, I don't know why I have been putting it off.
I swear it too 20 minutes. Air impact wrench helps a lot. Just put a jack unde the engine near the oil drain. Big improvement too.
Old 4th January 2010
hiros's Avatar
hiros hiros is offline
My Saabs: Saab 95 Aero M00
Have a look at the thread below on all four mounts replacement.
http://www.saabcentral.com/forums/sh...t=engine+mount
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
