Home Saab Pictures Saab Classifieds Saab Dealer Listings Saab Forum
Go Back   SaabCentral Forums > Saab 9-5 > Saab 9-5 Workshop
Saab 9-5 Workshop Saab 9-5 Workshop (1997 to Present day) Forum
Old 26-11-09, 01:08 PM
chucksings chucksings is offline
My Saabs: 1999 9-5
Default Please - where does this vacuum line go?
It is *possible* that where this line is located in PICS two and three (in the little guide clip under the brake fluid reservoir) may not be where it should be.
This line starts on the engine (PIC 1) goes upward and then snakes toward and under the brake reservoir and drops downward.
I cannot find an empty connector anywhere in that vicinity. If I put my thumb on the end of the line with the engine running it does choke a bit and I can hear suction on the line.
I have recently messed around with the throttle body, changed the thermostat and radiator.
Any idea where this line should connect?
Thanks
ID:	15232   Click image for larger version
ID:	15233   Click image for larger version
Old 26-11-09, 01:09 PM
My Saabs: 1999 9-5
Default BTW --- 1999 Saab 9-5 2.4
Sorry for lacking the vitals
Old 26-11-09, 01:15 PM
Al's Red Wagon's Avatar
Al's Red Wagon Al's Red Wagon is offline
My Saabs: 1999, Cayenne Red 9-5, 2.3 Wagon
That is the Automatic Transmission breather tube. It routs behind the Maxi Fuse box and then just hangs there and vents to the atmosphere.
copyright © 2003 saabcentral.com, All rights reserved - website by WDD serviceshttp://www.whiter.co.uk - valid xhtml - valid css
SaabCentral is an independently run website and is not affiliated in any way to Saab Automobile AB
