What's this thing (and why is it leaking oil?) - SaabCentral Forums
Old 22-11-09
JMarkert's Avatar
JMarkert JMarkert is offline
My Saabs: 2004 9-3 linear
Default What's this thing (and why is it leaking oil?)
I've been trying to track down a small oil leak for a couple months. I cleaned everything off and watched for fresh oil. I had at first suspected the PS pump that several folks have had trouble with, but it turns out the culprit is the thing behind it. Does anyone know what it does? It's still hard to tell, but I'd guess that the shaft seal coming out of the motor is the true source of the leak.
Old 22-11-09
aerojon's Avatar
aerojon aerojon is offline
looks like the combustion detection module..
ICM3 13sp system now with bluetooth audio streaming..
Old 22-11-09
WooSAABy's Avatar
WooSAABy WooSAABy is offline
My Saabs: 2006 93 1.9TiD (175) Hirsch Vector Sport
It also looks like it has a part number on the side!!
post the part number and all shall be revealed!
Old 22-11-09
jlrdrony's Avatar
jlrdrony jlrdrony is offline
yes, it is the CDM, fuel metering unit, part of the engine electronic for injectors, coil spark plugs and engine module.
the oil leaks must be due to the head cylinders gasket (rocker gasket).
my son get this problem with 2.0T.
Old 22-11-09
cadcamjim's Avatar
cadcamjim cadcamjim is offline
My Saabs: 2006 9-3 Sportcombi 2.0T, 5-M/T
I always thought that was the vacuum pump for the brake servo.
Old 22-11-09
JMarkert's Avatar
Thanks, folks. The part number on the black plastic thing is 12787708, BUT, I'm not sure this is the part in question. The black thing is attached to a round metal thing with a bracket. The round thing is sort of like a smaller tuna can, looks for all the world like it has a rotating shaft going into the motor. I seem to remember once that we had a vacuum pump, could that be it??
Old 22-11-09
WooSAABy's Avatar
12787708: Description : Jonization module
usage:2003-2004
WTF is a Jonization module??
Old 22-11-09
OlegShv OlegShv is offline
My Saabs: 2008 Volvo V70 2.5T
usage:2003-2004
WTF is a Ionization module??
I suspect that it is responsible for knock control.
http://www.asashop.org/autoinc/dec2002/techtips.htm
Old 22-11-09
JMarkert's Avatar
LOL, yes, that must be a typo in the WIS, Ionization makes a bit more sense. Google further down in my searches on jonization I did turn up some stuff on theoretical plasma physics, but i'm guessing IONization.
Anyhow, i think that the electronic module isn't really connected to the more deeply burried thing. I think cadcamjim's note that came in just before my clarification is right. If it is the brake servo vacuum pump, does anyone know how it's put together? I'd still put $ on the idea that the pump itself is OK, but the seal between it and the engine block is gone. Of course it's hard to see much detail since there are so many wires, hoses, and modules in the way. Or Jlrdrony might be right, the valve cover gasket could be leaking, but it looks mostly like its coming from lower.
Old 22-11-09
JMarkert's Avatar
OK, I've edited the picture to make things a little more clear - the part in question is the metal can shaped thing. You might need to hit reload to make my arrow appear - it turns out it happens to be attached to the black electronic stuff, but only by a bracket - I don't see any electrical connections. If cadcamjim's idea is right, does anyone know how to R and R it? I'm hoping that unlike the PS pump, I'm not contaminating anything with this small oil leak and that it's just dripping down the side of the motor.
Old 22-11-09
aerojon's Avatar
no pic now
Old 22-11-09
JMarkert's Avatar
Originally Posted by aerojon View Post
no pic now
Sorry, and thanks! Hopefully fixed now aero?
Old 22-11-09
aerojon's Avatar
yep...
Old 23-11-09
JonV JonV is offline
Saabista
My Saabs: 03 Vector
Throw some Tracerline UV Dye in the Oil......
Old 23-11-09
JMarkert's Avatar
Thanks Jon - I don't think there's much need for that - I can definitely see the oil coming out from this assembly (or, more importantly, most areas of the motor are squeaky clean except for a trail under this widget).
Old 23-11-09
Ridenbaugh Ridenbaugh is offline
My Saabs: Was 2004 9-3.
You are correct, I found it in the WIS.
JM, do you have a WIS? Basically it looks like this vacuum pump is similar to the power steering pump in that it connects directly to the cam shaft. From what you say it sounds like you might either need to tighten it or replace. There is a seal where the unit meets the side of the engine, I don't however know if you can replace it alone.
replacement steps seem extremely easy and could most likely be done faster than a power steering pump. there are actually only 4 steps.
Good Luck!
btw... the part number on that unit for my car is 12787763(but i can't seem to find any record of it)
Old 23-11-09
JMarkert's Avatar
Thanks Ridenbaugh - I don't have the WIS, but I'll look later to see if alldata has a procedure. Or maybe I'll figure out how to get me a WIS.
From what you say, there would be two potential sources of a leak, one might be the seal around the rotating shaft, the other would be a failed gasket between the pump and the motor. Does that make sense?
Old 23-11-09
aerojon's Avatar
vacuum pump..
Old 23-11-09
Yes, it makes sense. But I'm not real sure where what seals are aside from the one in the pic. I'll attach a pic that maybe will help you out.
hint hint... IDM is the abbreviation for Ionization Detection Module. undo the two bolts holding it on and you can move it out of the way to get a close look at your problem area.
Good Luck!
Old 23-11-09
this is a little off topic, but while he are on the semi-subject. Are there any actual benefits from having the power steering pump and vacuum pump connected via the cams? In the past with the power steering pump at least it was tied in with the S belt. Never had one leak that way...
