01 aero sid clock - SaabCentral Forums
Old 21-11-09
Xanimal13 Xanimal13 is offline
My Saabs: 2001 9-5 Aero A/T
Default 01 aero sid clock
Hey all. My clock doesn't light up. Its functioning as you can see the numbers its just extremely dim how can I fix this to make it shine? Also are the buttons on the sid supposed to light up? (Clear set - + night panel) are they backlit or no. Mine aren't...
Name:	2009-11-07 17.56.02.jpg
Old 21-11-09
raquettelaker2's Avatar
raquettelaker2 raquettelaker2 is offline
My Saabs: 2004 9-5 Aero, 2001 9-5 SE V6 (sold)
The bulbs are out. There are six bulbs in the SID, two for the buttons, and four for the display. eEuroparts has them, unfortunately they're about $6 per. You can pop the SID out carefully with a butter knife, although sometime they're stubborn and you need to push them out from behind by removing the radio. The bulbs come out with a quarter-turn clockwise.
Old 21-11-09
Oh thats good that I can replace them. I wonder if they are pick up able at my local autozone...
Old 21-11-09
I promise they are not at AutoZone.
Old 21-11-09
Bawww I don't wanna order them
Old 21-11-09
valbowski1980's Avatar
valbowski1980 valbowski1980 is offline
My Saabs: 2005 9⁵ Aero
Garage
I bought replacement bulbs for $1.20 a piece from a local electronics store (not Radioshack)... Just pulled up the old invoice and they are called "Lamp 8640".... You will have to re-use the base from the dead bulb though.
There is a "replacement for displacement".... It's called "forced induction".
Old 21-11-09
I'm not quite sure I follow what do you mean re use the base?
Old 21-11-09
Garage
The bulbs behind the SID come mounted on a gray plastic base that twists into the back of the SID itself... That gray bit will have to be reused... Kinda like the project here for the heated seat switch bulbs.
Old 21-11-09
Route 17 Route 17 is offline
My Saabs: 2006 9-5 2.3T
Replacement instruction for the light bulbs in the SID at Fixmysaab.com
with pics
http://www.twinsaabs.com/9-5_repair/...p?nsteps=1#SID
Old 22-11-09
with pics
Seems extremely easy...
