Oil Leak - SaabCentral Forums
Old 17th November 2009
ctown95's Avatar
ctown95 ctown95 is offline
My Saabs: 99 9-5 SE
Default Oil Leak
My 1999 95 v6 seams to leak oil from the place where u add oil. It looks like it is leaking from where the plastic piece meets the valve cover. When pressure builds the oil seams to be forced out where the plastic meets the metal. Has anyone else had this problem or anyone know a fix for this problem?
LeoLegend LeoLegend is offline
My Saabs: 2001 Aero Wagon
what is your oil level like? seems like it might be overfilled. If not, there should be an o-ring in that spot that might need to be replaced.
ctown95's Avatar
My Saabs: 99 9-5 SE
My oil level is a little below normal. How do you remove that plastic piece from the valve cover and where can i get an o-ring for it.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
