Just blew off my head gasket - SaabCentral Forums
Old 16-11-09
saab info saab info is offline
My Saabs: SAAB 9-5 SE 2001 2000 cc 4 cyl
Thumbs down Just blew off my head gasket
Friday on the 13-11-09 driving home suddenly i heard a puffing noise and saw some white smoke from my back window .After 2-3 km i saw the temperature rise. Fell on the side and then the temperature went red . The upper hose from cooler to engine had split at length for about 25 cm . Naturally all the water was gone. I changed the hose filled some antifreese and tried to start the engine but no luck . While turning the engine i had bubbles from the expansion tank and the engine wouldnt start . I m expecting for the mechanic to open up to see but i expect a burnt out head gasket etc . The thing is that on the panel the red triangle is permanently on although there is water level and oil is O.K and i dont get any codes from OBD .How will i erase the red triangle signal because i think is working as a malfunction switch
By the way is it common after major repair if you have to machine the head cover that eventually will damage the turbo shaft because of contaminated oil
Old 16-11-09
Carson89's Avatar
Carson89 Carson89 is offline
My Saabs: 03 9-3SS Aero
Garage
What you just described is very similar to what happened to my 2000 9-5 9 months ago when it blew its head gasket. Only difference being I didn't get any white smoke out of the exhaust.
Generally speaking if you get a consistent stream of little bubbles in the expansion tank after the coolant system has been bled, its a head gasket and air from the cylinders is being forced into the coolant system.
I would suggest getting the cylinders pressure tested to check whether it is a head gasket or not.
As far as the warning triangle goes, I am not sure. Though you can pull the ECU fuse (No. 17 I think) and leave it for a minute or so which will reset the management system and should remove any error codes, etc.
Good luck with getting it fixed.
03 9-3SS Aero (Maptun Stage 1)
