Whistling noise - SaabCentral Forums
Old 15-11-09
EdUaRDo2 EdUaRDo2 is offline
My Saabs: 93T
Default Whistling noise
Hi,
I have a 2003 Saab 93T that makes a TEMPORARY whistling noise every time I turn the engine on and ONLY AFTER the car has been parked for hours. That means every morning before going to work and once I get off of work, but any other time it's fine. The noise will stop just after a few seconds (15-20 sec)
It sounds as if there's air being sucked through a tiny hole in the engine next to the power steering container. I'm thinking the Turbo has something to do with it.
Any ideas of what it could be? I'll appreciate it greatly
Old 21-01-13
nkrptd's Avatar
nkrptd nkrptd is offline
My Saabs: 03 9-3 linear
I just got this same noise in about the same place this morning and this afternoon leaving work.
I had a look for airleaks and looks ok, and with it only making the noise when starting up, I'm suspecting something to do with SAI valve, hopefully not the pump.. Heres a thread to check out - http://www.saabcentral.com/forums/sh...d.php?t=116411
Old 21-01-13
iksnoved25's Avatar
iksnoved25 iksnoved25 is offline
My Saabs: 2003 Saab 9³ 2.0T Arc
Garage
I sometimes tend to get a really high pitch noise upon cold start up...it kind of sounds like the "noise" when you clench your jaw together really hard...
Old 21-01-13
DinoFrank's Avatar
DinoFrank DinoFrank is offline
My Saabs: '03 9-3 Arc
Garage
If your car has a SAI system, then it's the SAI pump. The pump makes a small whistling sound for the first 20 seconds during a cold start. It's normal.
