P1312 and P1334 Error Codes - SaabCentral Forums
Old 10th November 2009
tmg19103 tmg19103 is offline
My Saabs: '03 9-5 Aero Sedan, BLK/Tan
Default P1312 and P1334 Error Codes
So I got a CEL and pulled the codes with my OBD2.
Got P1312 and P1334.
Car is 2003 Aero with 54,000 on it.
I assume DIC and ordered another for great price. Also time for new sparks and ordered them.
I'm assuming this will fix the problem. If it does, will it reset the error code when I replace the DIC or do I have to reset the error codes with my OBD2 and assume I fixed the problem if CEL does not come back?
Also, if the error codes come back, what could it be given new DIC and sparks ?
gghh gghh is offline
My Saabs: BMW 530D Touring xDrive
If CEL returns it could be a cheap copy of the DIC.....
Hmmmm. I guess we shall see. I can always turn off the CEL with my OBD2 by clearing the codes, but I guess the error codes and CEL could return on re-starts.
Anybody else have this problem with new "cheap" DIC's?
I'm assuming Saabusaparts.com sells reputable DIC's. Site states "genuine" Saab parts.
mnztr mnztr is offline
My Saabs: 2004 9-5 Arc wagon
Yes those are self clearing codes which will reset after a few engine cycles. I would let them reset on their own to be sure the problem is resolved.
bcsteene bcsteene is offline
My Saabs: 2003 Saab 9-5
From my experience the codes didn't reset automatically. You can reset the code by disconnecting the negative terminal on the battery (or pulling the fuse for the engine management system) and let it sit for about 10 minutes, this resets the computer and will clear any error codes you have. If you drive over 50 miles without a CEL light coming on again you'll know you've fixed the problem.
raquettelaker2's Avatar
raquettelaker2 raquettelaker2 is offline
My Saabs: 2008 Turbo-X, 1994 c900 CommEd
The CEL will shut off after three starts. Literally, I sat in my driveway and started my car three times when I replaced my DI cassette and the light shut off.
Those codes are definitely DI cassette codes. Put a new DI in, swap the plugs while you're at it, and you won't have any troubles. A SaabUSAParts DI cassette will be Genuine OEM Saab and work fine. There are some cheap knock-offs *Made in China* floating around on eBay that have proven to be very troublesome.
Thanks all. I figured that was the problem. Also not bad price at sUSAp's on an OEM DIC - $204.00.
Franks! Franks! is offline
My Saabs: 2004 95 ARC
I also jut ordered the DIC from them. Hopefully this solves my Cel issues also.
Old 14th December 2009
Kool95Goon Kool95Goon is offline
My Saabs: 04 9-5 Arc wagon
Hi everyone,
I am a newbie to this forum.
I have scanned my 2004 95 wagon and these three codes come up P0340, P1312 and P1334.
After reading a few of these posts. I am assuming it is the DIC.
Would you say this acts as a cam sensor since there is no cam in this car?
I took the car to Saab and told them the codes. They refused to tell me what they meant unless I paid them $130 to do a scan which I already did with my friends brand new OBD2.
I am a bit reluctant to take it back there for servicing.
Does anyone know a good Saab mechanic in the Toronto area?
I have a third party warranty and I am also wondering if they would cover this.
Old 15th December 2009
Welcome Kool95Goon, to the Saab Central Forum! This forum is great, and has a lot of wisdom to offer. With a combination of these codes I would first change the spark plugs - make sure you get the exact kind specified for your car, and make sure the gaps are set correctly. If this doesn't solve the problem, I would try to replace the DIC (it would work best if you could borrow a working one from someone to try just in case this isn't the problem.) A third thing I might also check before I get a new DIC is to check the turbo wastegate rod retaining clip. These tend to rust and fall off. This was the problem on my 2003 9-5, the symptoms were a lack of power and the CEL was on. It's easy to get at and is under the heat shield on the front of your engine. See below thread:
http://www.saabcentral.com/forums/sh...d.php?t=168980
Anyway, good luck, hopefully you got some pointers now.
Replace DIC and spark plugs.
P0340 Camposition Sensor error (Camposition signal is generated by DIC)
P1312 Combustion Signal Cyl 1+2 Shortage
P1334 Combustion Signal Cyl 3+4 Shortage
Old 14th June 2010
mdev mdev is offline
New Member
My Saabs: 2003 9-5 linear
Default Saab mechanic Toronto
Kool5goon, Just reading this now (getting the 1312 and 1334 error codes), but regarding mechanics in the Toronto area, I've taken my Saab to Beacon motors several times: http://www.beaconmotors.com/
They speecialize in Saab, I think that's all they work on.
I've been quite satisfied with the work they've done there - no nonsense, no upselling.
Old 14th June 2010
rhcoleman rhcoleman is offline
My Saabs: 2003 9 5 Linear; 2007 SportCombi
Default reset engine management
Sounds like seeing if it resets after 3 tries is good advice-- however, what I did with this problem was pull fuse 17 while I was installing the new DIC (you got a bit better price than me, but I was still happy with USD258 delivered) and waited with fingers crossed to see it CEL returned. It hasn't so far, but earlier when I was hoping it was just plugs and did the same thing with the fuse, it came back within a day, so -- if there's a problem with your DIC and you clear the code, it'll be back.
Old 15th June 2010
No new CEL's for me. Replaced the sparks and DIC when I got the P1312 and P1334 fault codes in October and I have been good to go ever since.
Old 15th June 2010
jsmith jsmith is offline
My Saabs: 2003 9-5 LNR BCB STG 1
This thread made me go on ebay to look again. I didn't see any chinese knock-offs, but there are a lot of used ones. I already have a spare - in fact I haven't taken it off to put the new one in yet. I have to check for codes again sometime soon. Last I checked it was clean....
Old 14th June 2011
llhoc17 llhoc17 is offline
My Saabs: 2003 saab 9-3 linear 2.0t
Default error code 1470
my abs light went on so i took it to a local mechanic he said he was able to clear one code but the other was the 1740 code and he was unable to tell what it is because saab doesnt release the information. he said if he tried clearing it it would come right back. does anyone know what this code is for? is it a speed sensor or something...thanks...i meant 1740 in the title it was error code 1740 not 1470 sorry about that
Old 14th June 2011
justinsaab's Avatar
justinsaab justinsaab is offline
My Saabs: 2001 Saab 9-5 2.3T
Did you check with Saab to see if the DIC Recall applies to your vehicle and had ever been performed?
Old 18th June 2011
sakpase sakpase is offline
My Saabs: 200 9-3 Vector 6 speed
what's the website where you found it for that price because i can't seem to find it for that price
Old 18th June 2011
Jssaab Jssaab is offline
My Saabs: 2000 9-5 320hp, 2003 Aero Hirsch "Clone"
try saabpartsusa and remember that post was over a year ago
Old 18th June 2011
i can't find it for that price the lowest i can find it is $265 i guess i am out of luck. i keep on getting p1334 and p1234 no matter how much i reset the dam thing it keeps on coming back i have ngk iridium spark plug. it used to do that before i got a used one and it was good for a while and now it started doing that again. Parts for this car is too expensive man
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
