When to change the Timing Chain - 2003 9-5, 2.3T - SaabCentral Forums
Old 1st November 2009
tfrag tfrag is offline
My Saabs: 2003 9-5 Linear Wagon
Default When to change the Timing Chain - 2003 9-5, 2.3T
I've heard 60,000 miles is when to change the timing chain... I don't know. What is the answer?
I'm at 60,000 now and wonder if it is time to do it.
justin.graeff justin.graeff is offline
My Saabs: 2000 9-5 Aero
I am pretty sure that unless you can hear the chain hit the side of the valve cover, then you don't have to change it. On my '90 9000, you can hear the chain pretty loudly when I first start the car, then dies down a little as it warms. That car as 200k miles. My 9-5 has 150k and I can't hear it at all.
AIM: hyperspaztik49
Skype: Justin.Graeff
gbest gbest is offline
My Saabs: 08 Vert Aero T2
Which engine does your car have?
The 6 cylinder has a timing belt which should be changed,(along with the tensioner) at 60k miles.
The 2.3L 4 cylinder has a timing chain, that should last a lot longer (200k+).
2014 Infiniti Q50 Hybrid Sport
SaabScott's Avatar
SaabScott SaabScott is offline
My Saabs: 2006 9-7X 5.3i
Timing chains do not have a projected life span the way a belt does.
Ask yourself this ... when do I replace the springs on my car?
When they aren't working properly and there is an indication of this.
A timing chain is the same.
Either it will stretch or the guides will wear ... if either does it too much, you will be able to hear chain noise as the tensioner will no longer be able to manage the tension.
President,
The Saab Club of Canada
2006 9-7X 5.3i
That's great news - I'll monitor it and leave it alone.
You guys are alright!!!
Thank you.
Old 2nd November 2009
aemeeich aemeeich is offline
My Saabs: 2000 9-5 AERO, 1996 9000 CSE, 1988 9000T
The way to tell is to remove the chain tensioner and see how far it is extended.
My 2000 AERO with 150,000 miles had a stretched chain that I just replaced last month. The tensioner was at 17mm - the recommended max is 15mm. I didn't have any strange noises yet as there was still one more click on the tensioner to go, but if it would have gotten that far, there would have been problems.
Michael
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
