Saab 95 - Turbo - loss of power? - SaabCentral Forums
Old 19th October 2009
trickydicky trickydicky is offline
New Member
My Saabs: Saab 95
Default Saab 95 - Turbo - loss of power?
Hi all, first time poster so please bear with me!
I have a 1998 Saab 9-5 (4-cyl, petrol, LPT Ecopower), with stacks of miles on the clock (160k).
It’s been running fine, until around two weeks ago, when it lost all its ‘usable’ power. By that I mean, it will drive ok, but is noticeably sluggish. For example, go up an incline and it’ll struggle to maintain the national speed limit, even in 3rd gear.
My immediate thoughts were the turbo wasn’t working, or there was a blockage to the injectors (being an LPT model I have no turbo gauge, so I can’t be certain).
I can’t see any other notable problems, i.e:
No warning captions
Starts fine, first time and idles normally (fuel pump powers up on first click of the ignition)
No smoke from the exhaust either on start up or after running up.
Smooth revs – no surges or splutters when driving (I carefully revved it at idle, and it went through the rev range ok).
No clanks, noises or bangs that would worry me, its simply just the drop off in power (Also, there was no symptom preceding this drop off in power, the effect seemed to just happen without related problem or other warning sign).
What I’ve already changed:
New sparks plug fitted
Air filter changed
…..Both to no effect
Any ideas? I’ve heard about checking for vacuum leaks (?) but I really don’t know how to do this. I’ve also read about a ‘waste gate’ valve or ‘blow off’ being faulty – it doesn’t appear too expensive or difficult to replace – might this be worth a try? (Please see the attached photo, is this item the correct gate/blow off valve?)
Thanks for any help you can be!
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Has the clip that attaches the wastegate rod to the turbo come off?
New Member
My Saabs: Saab 95
Sorry, you’ll have to excuse my technical ignorance!
Where am I looking for the waste gate rod?
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
On the turbo which is under the big silver triangular heat sheild at the front of your engine - make sure its cold before you start to play!
I think the sheild has one 13mm nut holding it.
New Member
My Saabs: Saab 95
Thanks!
Well the clip appears half-broken, but the rod is in place and stays put when I apply a bit of force.
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Originally Posted by trickydicky View Post
Thanks!
Thats a shame, a detached one would act as you describe and its a very cheap fix
New Member
My Saabs: Saab 95
Could it be the waste gate valve itself?
From your labelled photograph, I take it the valve it the small unit on the left (from the perspective of looking at the photo) from which the rod runs out of?
Old 7th December 2009
Turkish Aerolines's Avatar
Turkish Aerolines Turkish Aerolines is offline
My Saabs: MY05 9-5 Aero Wagon
I wonder if it is the same for 2005 Aero (I have 2006 spec TD04 turbo). I have a photo taken previously and this is how it looks from this angle. I can't really see a clip but there seems to be a small thingy.
Is there also a certain number of threads on the westgate rod? Someone told me that he recalls 11 threads connecting to nut and I have 8. What difference would it make to have 3 less threads?
Name:	benim westgate.jpg
gghh gghh is offline
My Saabs: BMW 530D Touring xDrive
There is no certain number of wastegate threads. Once adjusted it doesnt unadjust suddenly, except the clip is lost. Check all the vacuum lines, heck if the turbofan is turning by turning it with your fingers.
Old 8th December 2009
Thumbs down
Can you let me understand more clear on this last part? Heck what? Turbo is installed on the car, how do I see the turbofan?
Remove intake cobra and try if you can turn the fan with your fingers - otherwise the bearing is seized up.
Old 9th December 2009
ccash ccash is offline
My Saabs: 2003 Black Saab 9-5 Linear
Chris 9-5,
That is one very clean and very good looking engine!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
