2003 9-3 heater fan switch fuse - SaabCentral Forums
Old 17-10-09
jeffster jeffster is offline
New Member
My Saabs: '03 9-3 SS Linear
Default 2003 9-3 heater fan switch fuse
Hello. This is rather trivial, but I need to look at the fuse on the heater fan switch, since the fan isn't working. The owner's manual is in the glove compartment, and this is the 2nd time the glove compartment won't open because something is jammed behind it. Please advise the fuse location. This is for an '03 9-3 SS Linear. Thanks in advance for taking the trouble here.
Regards, Jeff
Old 19-10-09
New Member
Actually, I need both the fan motor fuse # and location and also the fan switch # and location. There are two possible locations for fuses on this vehicle. Thanks.
Old 07-05-11
anup_vader anup_vader is offline
New Member
My Saabs: Saab 9-3 2.0T
Default saab 9-3 2003 Linear
Had similar issue on my 2003 Saab 9-3 linear.
The fuse box is located on the left side of the steering wheel, facing the driver door. Snap it open. Per my car's manual i had to check fuse # 18 and #23. See if those are burned out. You should find the replacements in nearby AutoZone easily. Costs <$15 bucks.
Next step, troubleshoot as discussed here - http://www.saabcentral.com/forums/sh...d.php?t=136459
