95 Aero Clutch Life - SaabCentral Forums
Old 13-10-09
Chris95Aero Chris95Aero is offline
My Saabs: 95 Aero
Default 95 Aero Clutch Life
My 2003 95 Aero has 75K on it and it's still on it's first clutch.
It may be my imagination but 3rd gear seems a bit harder to engage these days so it may be that the clutch is starting to go.
I was wondering how many miles others got from their original clutch?
Old 13-10-09
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Hiya, I cant actually answer that but.........
My first 9-5 ran on the LPT clutch even at 280 bhp, and my current car runs the aero clutch which is so strong the gearbox gave up first
Sorry I know its not much help but i thought I'd give a thumbs up for their wearability!
I guess a lot will depend on the type of journey and who is driving - my wife can kill a clutch in just one supermarket car park
Old 13-10-09
toxicavenger's Avatar
toxicavenger toxicavenger is offline
My Saabs: 2006 9-5 Sedan, 2006 Sportcombi
There isn't a certain time your clutch goes out. You might beable to even check and see if the bushing are worn out on your ****er. And Chris I know exactly what you are talking about with a woman driving a clutch!
Old 13-10-09
SaabScott's Avatar
SaabScott SaabScott is offline
My Saabs: 1993 900S
Mine is over 150K miles.
President,
The Saab Club of Canada
www.SaabClub.ca
1993 900S
Old 13-10-09
photousa's Avatar
photousa photousa is offline
My Saabs: 2003 Saab 9-5 Aero Wagon 2.3T HO Manual
My clutch has 121,000 miles on it and it's never been changed. I am however, buying everything I need to change my gear oil. I've read where a gear oil service change can smooth shifting.
2003 Saab 9-5 Aero Sport Wagon >>> My other home: http://saabworld.net/forum.php
2.3T HO B235R Manual
132,500 miles http://youtu.be/TZDGk5NXdh4
Old 13-10-09
saabysteve's Avatar
saabysteve saabysteve is offline
My Saabs: 84 GLi & 90 VERT
Be surprised if its the clutch, Im a driving instructor and get a good 100k out of the teaching cars I use( with the exception of a 2008 corsa, only 19k on that one!!!!!)
Old 13-10-09
valbowski1980's Avatar
valbowski1980 valbowski1980 is offline
My Saabs: 2005 9⁵ Aero
Garage
It's all about how you drive it (or how the previous owner drove it). At 150 on the clock my LPT clutch just started slipping after Stage 2 power was added.
There is a "replacement for displacement".... It's called "forced induction".
Old 15-10-09
My Saabs: 95 Aero
Thanks for all your repsonses guys.
I'm the owner from new so I know it's history, which is as sympathetic as you can be while driving pretty hard! To be fair I always double de-clutch on fast down shifts and never use the clutch pedal as a foot rest so I would expect a better than average life.
Seeing some of the mileages quoted gives me heart that there's not another big bill around the corner!
Old 15-10-09
larrylamb11 larrylamb11 is offline
My Saabs: 9-5 Aero Wagon
Be warned, my Aero started to get difficult into third before the gearbox failed - it was literally the first clue as I noticed it getting notchy.... then 2nd gear synchro failed, followed by the rest of the box. It may pay to do an oil change and refill with the upgraded Saab gearbox oil, checking to see if there is any evidence of heavy wear stuck to the magnetic drain plug - a drain / refill will use 2 litres of oil.
As for the clutch, the one removed from my Aero when the box was changed had done 128k miles and still had plenty of life - the Haynes manual reckons a new clutch is 7.5mm (or 7.3mm or something) thick and min thickness is 5.5mm. Hope that helps.
Old 15-10-09
My Saabs: 95 Aero
OOO-EERRRR!!
What was the approx. cost of a new/recon gearbox when yours failed?
Old 15-10-09
My Saabs: 95 Aero
I just had a 66K service, would they have changed the gearbox oil during that I wonder?
