| Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum |
Hey guys so a couple days ago I started getting a miss and its got progressively worse. So I have been doing what I can starting out cheap. So far I've done a full fuel injector cleaner and new spark plugs without any results. This leaves a completely bad fuel injector or a bad coil/ Direct Ignition Cassette right? If I smell the exhaust I can smell the unburnt fuel so I'm thinking its not the injector and that it has to be the coil. Is there any way to just replace 1 coil? I'm a broke high schooler and I'm trying to stay as cheap as possible. So does anyone know where I could get a Direct Ignition Cassette for relatively cheap cause I don't really have $400 to drop on one unless I really have to. So any advice on repairing the one I have or testing or where to one cheap would be VERY much appreciated! Thanks in advance!
-Evan |
| Sponsored Links | ||
Advertisement | ||
If you have a bad miss at idle or under load it's more than likely your spark plugs and or the DI Cassette.
You need to get the proper BCPR7ES NGK spark plugs the owner's manual calls for and gap them to .9 mm. You can't repair the individual coils in the DI cassette, You can find a good used Red DI cassette, instead of buying a brand new one. If you are in the Denver, Colorado area try Mile Hi Saab or East of Sweden to see if they have any used ones. All of the junkyards around here are pretty dry for 9000's and no DI cassettes out there in the 9000's which are there. |
The guy at Checker is wrong and doesn't know about Saab's with the DI cassette! Never use anything but the specified NGK BCPR7ES plugs for the car. You can and will cause early DI death by using the wrong plugs.
Both Mile Hi or East of Sweden should have the correct NGK plugs too. Nope, don't have the T5 suite here....my ,92 9000 has the DI/LH system. Not running Trionic. |
Always use the NGK. The sites may say you can use different brands, but saabs designed their engines around the NGKs to perform best. Get the plugs the manual states and gap them to .9mm and see how it runs. If you need a DI cassette, I have an extra that I can sell you.
AIM: hyperspaztik49 Skype: Justin.Graeff |
I ran down to East of Sweden today and got a new DI Cassette and four NGK BCPR7ES like u all recommended and the missing is gone and its running like its happy old self
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
