C900 Distributor Oil Seal - SaabCentral Forums
Old 30-09-09
bostin's Avatar
bostin bostin is offline
My Saabs: 1989 C900 T16S
Default C900 Distributor Oil Seal
My T16S, (SPG/Aero) is leaking a little oil through the distibutor. I'm told by some WYSE guys (West Yorkshire Saab Enthusiasts) that it's the oil seal on the distributor.
Had a Google and a hunt around the forums here and elsewhere, but can't find a conclusive guide on how to fix this.
I have the part number for the seal, but I could do with a step by step guide/procedure.
Thanks
Al
Parking sensors? Isn't a towbar cheaper?
Old 30-09-09
finbarr's Avatar
finbarr finbarr is offline
My Saabs: 1993 900i auto convertible
Hi and welcome, very straight forward really.
There is just the one "fork shaped" clamp securing the distributor to the engine which is in turn held by one bolt.
Unscrew bolt remove clamp and dist. will just slide out. Re-fit is reverse, dist can only be installed/engage with cam inside in one way. But do label leads and the dizzy cap to avoid mix up on re-install.
They are good pics else where on this forum but this will help get started.
The old seal will not bear any obvious relation to the new seal other than both round, but its just the way it deforms over time. It is just the 1 seal.
In the pic its the black seal to the right on the dizzy shaft.
…my 200th post I think !
Old 30-09-09
TrollMedic TrollMedic is offline
My Saabs: Classic Saab 900,1 of 300
Where can one buy the dist. seal?
TrollMedic
Old 30-09-09
finbarr's Avatar
Saab would be the most straight forward. If ordering from an O-ring supplier you would need to specify both the internal diameter (ie the groove in which it sits) and the cross section diameter (for which the diameter of the aperture into which the dizzy shaft goes would be needed) of the ring.
And it would have to be a High temperature Nitrile type O-Ring.
Go Saab if possible.
Old 03-10-09
crwchf01 crwchf01 is offline
My Saabs: Menagerie of 14 and climbing
The distributor to head O ring is shown here, but if it doesn't solve the problem, there is an oil seal in the distributor shaft that will harden and leak. I don't have the link handy, but I do have a couple of the INTERNAL seals in hand from NAPA. They are staked in the body and can only be changed with a full teardown.
It's too late for blind faith and ignorance.... gotta get a bigger hammer.
Old 03-10-09
What is that NAPA part Number?
TrollMedic
Old 03-10-09
900t's Avatar
900t 900t is offline
Saabista
To specify ring dimensions is easier than trying to tell the Saab dealer guy what the seal is And it better be cheaper...
Old 03-10-09
earthworm's Avatar
Saab Sage!
I doubt if Saab carries the necessary seals....
To modernize and compete, the manufacturers and dealers must merge with , as an example, NAPA, and NOT even have their own parts department.
And then get the system out of the dark ages.
A computerized auto sales super center, as such.
http://www.900saab.com/dizzy.html
The earthworm
'96 900S, Automatic
Old 03-10-09
Max Blast's Avatar
Max Blast Max Blast is offline
My Saabs: '78 99T, '93 900T
I got the external one from NAPA digging through their o-ring box with the old dried out one in hand. It's a little thicker and the dizzy is a tighter fit now, but it fits nonetheless. Eeuroparts has the proper one for a buck eighty nine I think.
