Question on wipers - SaabCentral Forums
Old 28th September 2009
Havok's Avatar
Havok Havok is offline
My Saabs: 2003 9-3 Vector BCB Stage 2
Default Question on wipers
Just picked up my first Saab and I love it! Still learning all the differences to this car - I'm a convert from American muscle cars. Funny thing is, the original plan was to purchase this 2003 for a winter car, and a year later pick up a new Corvette. Now I am leaning towards getting a new Saab! Go figure...
Anyways, I have a question on the wipers: when I turn my wipers off, they immediately stop. I would think they would return to the bottom of the windshield, however they don't from any setting. Is this supposed to happen?
I am leaning towards this being a problem as I also seem unable to have the wipers work in delay mode; I am only able to push the lever down to manually wipe, or put them in slow or fast mode.
JonV JonV is offline
Saabista
My Saabs: 03 SE 5 Spd
Yes they should go back down. You may have control stalk problem
(Easy DIY and inexpensive) or a CIM issue, (not easy and Pricey). As far as Intermittent, try this, go up two steps with the stalk then back down one. I know that's not the way it's supposed to work, but for some reason every now and then I find I have to do it. Lastly, It could also be a problem withe the Rain sensor.
Diggs's Avatar
Diggs Diggs is offline
My Saabs: 2003 9³SS Linear
No rain sensor in 2003 Linear.
I'm not saying it's a coilpack.....but it's a coilpack.
Swink Swink is offline
My Saabs: 2005 9-3 Arc
I had same symptoms as Havoc, plus no wiper washer/squirter. I researched here and found that, strangely enough, the problem is the wiper motor and the solution is to replace it (about $250+labour). It seems like a relatively common problem.
I took the car to the dealer and they confirmed what I'd read here (not that it was common but that I had to replace motor). I tried to get GM to pay, but instead they just gave me 2 oil changes.
Hopefully, your issue is 'just' the control stalk.
Saabista
That would mean no-intermittent right? I don't know for sure, but wasn't Rain sensing availible in one of the Launch Model Packages?
Havok's Avatar
Thanks for the replies, I'll check it out. If it turns out to be expensive I'll just live with it. I've gotten pretty good at timing when to let up on the wiper already.
dlerch dlerch is offline
My Saabs: 2004 Aero Wagon
honestly if the problem doesn't get worse, i.e. wipers stop on their own etc etc..i think you will benefit from it more come winter than not having it. i had an old isuzu trooper that did the same thing. the benefit was that in the winter you can stop the wipers in the area of the windshield that gets directly hit by the defrosters. still out of line of site, but not "tucked" all the way down below where they can get some residual heat..this will obviously mean the wipers will not ice up!! so like i said it may be a good thing in a car that is already a great runner in bad weather. yours may be even better!!! JMO
Diggs's Avatar
No rains sensor on any package for Linear. I think only the Vector had those. Of course it has intermittent wipers. Most all cars in the last 20 years have.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
