I replaced the alternator mount bushings here not too long ago, maybe two months? For some reason I used regular rubber for the alt, and urethane for the tension arm.
About a month ago I started getting some belt squeal, so I checked the belts, they were a bit loose. I thought it was odd, but figured the rubber alt mounts were settling in and egged a bit like they always do, so I just readjusted belt tension and went on. Once again I started hearing a bit of squealing when cold or sometimes when I'd be releasing the clutch. I thought at first it was my harmonic balancer, but I marked the pulleys and the marks aren't moving. The belts seemed a bit looser than I usually leave them, but they were still tight enough I didn't think they should be squealing. So I removed the AC compressor to inspect the water pump, and that's when I noticed the Urethane alt tensioner mounts were crumbling away and I could wiggle the arm back and forth. The rubber alt mounts on the other hand, are still in perfect shape. What gives? I'm peaved. I have to replace them now, (woot fun!
James Bond shifted down into third gear, drifted the Saab 900 Turbo into a tight left-hand turn, clinging to the grass shoulder, then put a fraction more power to bring the car out of the bend. |
| Sponsored Links | ||
Advertisement | ||
Could also check that the water pump pulley has not been bent out of shape. Had one [*** EDITED ***] not tighten them right, and they loosened up, causing all kinds of problems, including worn and gone alternator mounts and a shot water pump pulley. Got stranded by that [*** EDITED ***]. Luckily not too far. Agree that it was not fun. Too bad that that [*** EDITED ***] liked listening to my C900 stereo with others and draining the battery till the C900 wouldn't start ... instead of working. |
Matt,
I've installed the urethane bushings in two of my cars without any problems so far. My understanding is the same as yours, that they are supposed to be better. There must be something contributing to the premature failure.
Steve Corgan, The Saabster 89 SPG Edwardian Gray, 90 SPG Talladega Red, 91 900 Turbo Beryl Green Vert |
Yep, mine disintegrated rather quickly as well. I replaced with stock rubber.
*1988 BMW M3* - Current project *1987 Airflow vert project thread* - 400bhp, Eurotuner Magazine Feature Car - Now on T5 *1987 SPG project thread* - Sold *1999 Lightning Blue 9³ Viggen* - Sold |
Not all Urethane is created equal!? Try better quality Urethane?
I went back with rubber, but in looking further for the cause I think my rear alt bearing is/has failed in my Alternator.
I'll know further tomorrow once I tear down the alt and take a look. Voltage output is fine, but it has some shaft play and I think the squealing was actually the bearing spinning. Here is a picture of the urethane bushings if anyone is interested. That's the last time I go with anything other than OEM.
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
