9000 trip computer - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 20th September 2009
Kermit's Avatar
Kermit Kermit is offline
Saabista
My Saabs: 04 9-5 Vector 2.2Tid
Default 9000 trip computer
Is it possible to do a straight swap from the EDU trip computer to the SCC version or is it more complicated than just swapping over the connections?
Old 21st September 2009
SaabKen's Avatar
SaabKen SaabKen is offline
My Saabs: '06 9 2.0T Combi, BCB Stg 2
Garage
What do you mean the EDU trip computer ? Do you mean from the analog clock to the SCC digital clock/computer ? It's fine if the connector is the same, I forget now but I believe the analog clock had two versions with the changeover around 1992.
2006 9 2.0T SportCombi BCB Stg 2 | 2004 Subaru Outback H6 3.0 | 1993 9000 CSE (RIP)
"Honesty is the best policy, but insanity is a better defense." - Steve Landesberg
Jeff325's Avatar
Jeff325 Jeff325 is offline
My Saabs: 92 9000 Turbo; 02 9-5 Linear
The DCC/SCC digital clock is the one that changed. The analog one is the same for all. The DCC was used up to 1991 model year. Then with the 1992 model year SCC was used.
Old 22nd September 2009
Mo_Flow Mo_Flow is offline
My Saabs: 1991 9000 turbo
Default Bad trip computer?
since you guys or on the subject, my trip computer reads error. i have a 91 9000 turbo. do i need a new relay? or a new computer? im new to saabs.
justin.graeff justin.graeff is offline
My Saabs: 2000 9-5 Aero
There are three different versions for our Saabs. The very early one, one for the 1990-1993 or something like that, and then one for every year beyond that. For my year, all I had to do was find the cable that was buried in my dash. I spend hours trying to find it, but I found it easily when I took the dash top off and looked through the windshield.
If you look through threads I started here and on Saab Central, you can find both of mine concerning the SCC and what one you will need.
AIM: hyperspaztik49
Skype: Justin.Graeff
SaabKen's Avatar
Garage
What's DCC ? Digital Car Computer ? How was it different than the SCC ?
Jeff325's Avatar
DCC is the earlier version of the trip computer that was in 9000's up to model year 1991. The digital clocks for the DCC aren't that common, as I rarely ever see or find them on salvaged cars here in the US.
The starting with model year 1992 the 9000's went to the SCC. The earlier version of the SCC ran from model years 1992 to 1994. The digital clock on this version has 2 connectors on the back of it. The digital clock and EDU 3A or 3M display units from 1992-1994 will work within this year range.
Then with model year 1995 the SCC system was revised. digital clock went to one single connector on the back. There are differences in the 1995, 1996-1997, and 1998 model years. The digital clock or EDU 3A or 3M display units from 1992-1994 won't work but 1995-1998 will.
Old 23rd September 2009
SaabKen's Avatar
Garage
Although I swapped out my SCC for a regular analog clock (looks cleaner), this is what I had before (not my own car but same MY), presumably it's the SCC then ?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
