Checking the oil/oil overfilled... - SaabCentral Forums
Old 15th September 2009
mryan55 mryan55 is offline
My Saabs: 2011 Saab 9-5 2.0T Biopower 6MT
Default Checking the oil/oil overfilled...
Hi all,
Haven't posted in a while. Anyhow, my 2008 is now out of the free maintenance window, so back to doing my own minor work.
Anyhow, I changed the oil with 0W30 Total QuartzEnergy 9000 (one of the few LLA-025 oils in the USA), and everything is great so far. Fuel economy higher (was running 5W40 before).
Anyhow, I drained everything out and filled with 6L of oil. After running the engine to operating temp, shutting it down, and checking 5 minutes later, the oil level is slightly above the 'max' arrow. It is basically right on the dot atop of the hashed part of the stick. So, if the stick read on an exact, sliding scale, it might be 1/3 to 1/2 L beyond the hashed section of the dipstick.
Anything to worry about with it in this range?
Mike
greekfragma's Avatar
greekfragma greekfragma is offline
My Saabs: 9-3 1.8i >2003<
overfilling with oil is bad for your engine.
get it inside limits....
as far as I am concerned I prefer to have the oil a bit lower than max so it doesnt reach max under different temperatures.
JMarkert's Avatar
JMarkert JMarkert is offline
My Saabs: 2004 9-3 linear
I agree with greekfragma, but in your case it's a tough call. For sure a whole extra quart or two can cause foaming and interference problems, and ultimately lead to higher pressures and potentially blown seals. But I would guess that being 1/3 quart over won't do any harm.
If it's not horribly inconvenient, I'd suggest that you can put your gloves back on and drain out a half quart through the sump. Just back the plug out slowly and hold on to it (yes, it's messy, so put down some newspaper too and count on the oil running up your arm, so do it with the motor cool ).
If it is horribly inconvenient, I'd just let it ride. IMO, draining it out would be the result of an abundance of caution.
For future reference, while the spec might call for 6 quarts, in most cases you won't get all of the old oil out of the motor. Mine took about 5.5 quarts last change - and I let the oil drip and drain for almost an hour while I did other stuff.
JonV JonV is offline
Saabista
My Saabs: 03 SE 5 Spd
Did you also change the filter? if not, that could be the difference. Or you didn't drain long enough.
sraber sraber is offline
My Saabs: '09 9-3 Aero
Interesting. I just changed my oil and filter and put over 6 quarts (about 6 and a 1/4) back in before the oil level on the dip measured mid way between the stripes.... Now I'm wondering if I put too much in....
scott
JMarkert's Avatar
I don't think you need to worry overly much, as long as things look OK on the dipstick. I bet there's a little variation in the real capacity due to machining differences etc. And there will always be variation in how much oil is held up in the motor - it might even vary with exactly how the motor stopped, how warm it was etc. However, you might take a look at the dipstick just to make sure it goes all the way in etc. You probably would have noticed by now if it wasn't...
FWIW, the manual is a little ambiguous - it says '6.3 quarts (oil change)' , so maybe I'm the one who's using too little.
Changed filter and drained for 45 minutes. I'll take some out. No big deal there. Anyhow, at least this dipstick is easier to read than the one on my 99 9-3 and the 9-5 that I no longer have.
aerojon's Avatar
aerojon aerojon is offline
In 20 yrs of working on cars never known of a seal failing due to slight overfill of oil,all my cars have been overfilled by 1/4 litre/250ml non have blown or had seal failure because of this.And my second to last car before the 9-3 did over 190k mls..
engine oil level should be checked cold not hot..
Is still running factory oe coils with Hirsch tune..
Yeah. I suppose I'm not that worried. Especially with the turbo and canister oil filter means that the dipstick reading might not be 100% accurate.
jlrdrony's Avatar
jlrdrony jlrdrony is offline
I always check the engine oil level in cold conditions. it is slight overfilled by the dealer.
note: it is very important not get out bound the max. level of bar/level...................... damage the engine.
I had to take some oil out:
Saab's own recommendation for checking the oil on either the 4 cylinder or 6 cylinder gas engines is to check with the motor at operating temperature after being shut off for 3-5 minutes. Checking the oil in this scenario makes it just marginally 1/4 L over the full mark -- just covering the "full" lettering on the 4 cyl dipstick.
I don't really recall perfectly, but I seem to think the dealer was filling it to this level as well when it was under free maintenance.
Mike
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
