| Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-3 Sports Saloon/Sedan, Combi & Convertible |
Has anyone had any issues with ignition coils going out with a stage 1 BSR tuning system? This will be my third trip to the dealer with this problem. I don't know if the BSR tuning system is to blame or if there is another reason they are going out. When it is returned from the dealer it is fine for a while then the problem reoccurs. Any information would be appreciated!
| Sponsored Links | ||
Advertisement | ||
What are the symtoms of the problem? Stuttering at high rpm's at highway speeds?
Yes, it is a stuttering at full boost on the highway, typically in 5th and 6th gear. I am considering detuning the car to see if it still occurs because I want to know if it is a fuel shut-off issue rather than a coil issue. Any thoughts?
Have Stage 1 BSR, moves like an arrow.
Just did a sprint on "no man's land" a long brigde linking two states, and boost in 5th is phenomenal with the turbo needle at the orange/red border. Of course at the end of the run i saw the patriotic flashies, the OH troop clipped a Pontiac GTO just before getting ready to speedscape to the Mountain State Good luck with your problem. I would take the car to AutoZone and have them run free diagnostics with their advanced Actron scanners first, but i live 3 hours away from dealer.
UltimatePedals, USASpec PA-20GM iPod/Connects2-BTAV1, Llumar ATR15 tint rear, H&R spacers, Borbet-XL/Dunlop M3 18x8" winters, SAAB Euro Badge, Ital black frames, TurboX watch and driving gloves...Dart Vader's own anyday now |
My Turbo X "misses" in 5th and 6th gears at 2000-3000 RPM during WOT acceleration. I'm running 21psi of boost. Doesn't happen at stock 12psi boost. I'm going to check the spark plugs soon. Until then I've lowered the boost pressure down to about 15-16psi.
Nick Taliaferro claims bad Ignition Coils is the problem, but I do not have the money to replace them all at the moment. You have a bad coil... start replacing them 1 x 1 to figure out which one it is. |
Not a claim but experience with a halfdozen or so tuned up with the same symptoms.
You can gap the plugs down as a bandaid for weak spark at high cylinder pressures. I went through a handfull of coils before they would hold good with my 320hp ss. 4cyl BCPR7ES @ .8mm just to play Should be 1.0mm You an see it with the tech2 and move the coils around to see it move cylinders.
Nicholas Taliaferro GenuineSaab.com Since 2001 and nobody could spell Tali... | TrollTuner.com 2.0 GOOSE 500whp + 8500rpm = 11.06 @125 in -09 on a gt30 and stock gears E85 Viggen 488whp / 440wtq 12.43@114 | Nordic/GS E85 9-3 SS Aero 317hp / 350ftlbs | -72 v4 Wagon 95 120hp <The most fun of all |
After speaking to you on the phone about this Nick, I made sure I was gapped at 1mm. So without replacing coil, I could try gapping at .8mm and see if that works for awhile?
You also say Tech2 will tell us which cylinder has problem? Brad at Georges told me I didn't have any misfires, but they did get a knock reading. Couldn't give me any any info pertaining to details of an individual cylinder... =( although he was claiming the whole time that it was due to running lean, and a simple octane booster would fix the problem, lol. You are the only Saab 9-3SS mechanic I trust, I'm just going to have to drive down there soon. |
If I don't schedule a time with you by the next time you come up here, lemme know and I will for sure meet you at the track!!!! |
You are a brave man, definitely look into an Audi RS4 for a second stealth ride.
I had a very nice visit with my service manager today regarding this issue. Apparently the problem is widespread with the Turbo X and Saab Technical is working on a fix. The problem stems from the amount (%) of Ethanol that is in our fuel in North America. The way it was explained to me, the system was designed for no more than 10% Ethanol in the fuel and in fact in North America it can range from 15% to 22% depending on location. They are going to replace the bad coils that I have currently but they will in fact fail within a couple of weeks of replacement. I am hopeful Saab will issue a "Campaign" to repair the issue once an appropriate solution is found.
Threads like this don't make me want to mess with a tune on my car.
thanks for the update keep us informed.
New Whip 2011 9-4x Aero XWD My TurboX 02/08/2009 - 8/26/2012 RIP 3" Downpipe and Midpipe: http://www.youtube.com/watch?v=wZ3nPLrEeRk |
Seeing as how ethanol is more money than gasoline, there's no reason to add any more than necessary (10% is mandated by law). Allegedly, there's a Lexus recall to fix fuel rails that were damaged by "too much ethanol", but I have yet to see what the real story is on that one. |
If you could, ask your service manager exactly how excess ethanol causes coil packs to fail. I just don't see the mechanism there.
I will say this: putting too much ethanol in a tuned car could cause it to run excessive fuel trim, which will cause a CEL and may cause it to go lean in open loop. That could cause some issues. I like Nick's theory: increased boost causes increased cylinder pressures, which requires a good spark to ignite. Saab just has "substandard" coil packs (not really, they're just not good enough for a tuned car with lot of boost). Just like certain tunes require bigger injectors or turbos, maybe certain tunes require better coils. |
Faulty ignition coils where a common problem on Tuned V6 from 2008. They mostly come up when the car is tuned because the coils are without the tollerance they should be working within.
There have been multiple reports of tuned Turbo X cars failing on european forums when people got Hirsch Tuning. After replacing the coils for some from a newer batch, the problems where gone. The Ethanal theory sounds bull**** to me too. |
my turbo x is doing this
it seems to be worse with some grades of fuel but it is worse on the 99 octane ! been into the dealer and he says nothing is wrong He reset the ecu and it got better for a couple of days ... This engine is used in a vauxhall variant and their fix is cooler iridium plugs so is it coil packs or spark plugs ?
9000 aero stg 7 266k miles 500 hp six speed ! 9000 cs 2.0 stage 6 350 hp track slag 900 t16s classic 184k 9-3ss 2009 turboX sportwagon 69,000 miles |
The issue seems to be limited to the coils, the only issue with the spark plugs is fouling after the incident occurs. I am taking my Turbo X back in tomorrow per their request and I am going to ask about some higher capacity coils and gapping of the plugs. I dont know what this would do to the other parts down or upstream, but it seems a very reasonable question. I did ask why they wanted do the repair again due to a permanent fix not being available, and he told me that they wanted to "gather more engineering data" for Saab technical. This coil problem will affect all Turbo X cars, tuned or not.
Hopefully a resolution will be forthcoming. |
Hope it's soon as I have a little "stuttering" when stepping on it while cruising at 70-75 mph.
Why is this problem unique to just the turbo x.
So I'm right to think that the coil packs used on the turbo x are in fact different to whats used on my 06 2.8t, which could be modified by, lets say Brian at V, tune or BSR without this problem arising. If this is so, then is it not possible to fit coils that are specified for the earlier v6 cars to the turbo x, after all this problem doesn't appear to happen on earlier 2.8t's when modified (or does it?). It's just a thought....Perhaps someone could shed some light on this. Cheers! |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
