Wedge 83 95 238 - SaabCentral Forums
Old 01-09-09
SvrNScrN SvrNScrN is offline
My Saabs: 2002 9-5 Aero 5-spd Auto
Default Wedge 83 95 238
I am reading in the SAAB WIS about removing my head, and it mentions that I need Wedge 83 95 238. I can see the spot between the frame and the engine where I want to drive it in to hold up the engine, and I was thinking I could probably make this wedge from a peice of wood. Does anyone have the dimensions on this piece?
Old 27-11-10
lcamel lcamel is offline
New Member
My Saabs: 2002 9-5 Aero Sedan, 2001 9-5 SE Wagon
Did you figure out the dimensions for the wedges? I need to make a set as I'm changing the serpentine belt. These are called for to support the engine while the engine mount/bracket is removed.
I did see another suggestion that a floor jack could be used to support then engine instead of the wedges. Would be interested to hear if anyone has tried that method.
Old 27-11-10
19949KCSENA 19949KCSENA is offline
My Saabs: 2002 Aero Estate
I have no idea but isn't this the sort of thing that Saab independent dealers, and DIYers just bodge with whatever happens to be at hand?
Old 27-11-10
MacNoob's Avatar
MacNoob MacNoob is offline
My Saabs: 01 9-5 Wagon (RIP); 05 9-5 Aero (gone)
It's just a little chunk of wood about 3/8 to 1/2 inch thick.
Old 29-11-10
vividly's Avatar
vividly vividly is offline
My Saabs: 2000 9-5 SE (Sold), 2009 Ford Focus SEL
I just did my belt this weekend, along with the tensioner pulley. I used a block of wood on top of a floor jack (need something to distribute the weight across the oil pan, otherwise, the jack will make a hole - not good). Not too bad of a job once I knew what I was doing!
