Front bumper/spoiler damage - SaabCentral Forums
Old 31st August 2009
CVsaab06 CVsaab06 is offline
My Saabs: 9-3 Sport Combi
Default Front bumper/spoiler damage
My wife and daughter have been using the front of our saab as a shovel! The front spoiler and black grill directly above are damaged.
I've found the spoiler and protective undertray for the radiator. I cannot find out what holds the black grill to the spoiler (see where my finger is pointing) or any parts diagram. What holds that together?
Do I need to take the front bumper off to make the repairs?
thank you,
ID:	13807   Click image for larger version
win-low's Avatar
win-low win-low is offline
My Saabs: 03' 93 Vector - Silver (WOW)
thank you,
I think its some metal clips on the back side...Or the regular plastic tabs you find on most plastics snapped together. I thought I saw metal though
rogan's Avatar
rogan rogan is offline
My Saabs: 2003 9-3 Vector 2.0T
Geez... ouchy.
Smile
If anyone has an exploded view of the front bumper/spoiler/grill area, I could identify parts and fasteners. My lower black grill above the spoiler is loose and I'm sure there are tabs etc which hold this together. But, I can't find any pictures or diagrams of the parts.
I did find, in the archives, a great description of front bumper removal. I just don't want to take it off without having the parts necessary to put everything back together.
thanks for any help/diagrams/info
Jphoa Jphoa is offline
My Saabs: 2005 Saab 9-3 2.0T ARC
front spoiler and black grill do not touch at all. The blakc grill is integrated into the bumper. you can remove the front lip by just pulling it outward which will release the tabs. Im not to sure how to take the black grill out tho
Old 1st September 2009
Cool
My mistake in writing. The black grill part does not touch the spoiler directly. It does touch the thin strip directly below and I think there is some type of fastener which bonds the two. I can see notches where the black vertical parts of the lower grill must fit into the bottom of bumper. (right where my finger is pointing in the picture above)
Anyone have a diagram of this bumper section which labels parts? Or, do you know where I can buy a manual etc which would show part numbers and how everything fits together. I've done a bunch of searching and can't find anything for this area?
Old 8th September 2009
rrrrrr rrrrrr is offline
New Member
My Saabs: '04 9-5 aero
Default same problem, looking for parts
where'd you source your parts? For my 9-5 I need to find a replacement spoiler and the protective undertray for the radiator. Wish I could blame my damage on my wife and daughter!
CMerriman CMerriman is offline
My Saabs: None
I wouldn't let the wife or daughter ever drive your car again... That is complete negligence, and being a woman isn't a good enough excuse for something like that, lol.
Chris
Ambisaab's Avatar
Ambisaab Ambisaab is offline
My Saabs: 03 9-3 Aero BSR Stage 1 & JR Filter
depends what mood she's in
I had to respray mine a couple of months ago. I removed all the trim push type clips from underneath and the 8mm headed screws from each end and then just (bravely) pulled the skirt off. Maybe your being too kind.....as the bishop said to the actress...'Give it a good tug'
I'll shut up now !
Old 9th September 2009
Gs04aero's Avatar
Gs04aero Gs04aero is offline
My Saabs: 2004 VTuned Aero
Anybody done anything to secure the lip more? Mine seems to hang low. Not sure if thats just how its supposed to be but I can push the whole thing up with my hand and then it drops about 1/2 inch when I let go. Normal?
Kandiru's Avatar
Kandiru Kandiru is offline
My Saabs: 2008 Turbo X Sedan 6-Speed Navi
1) W/o headlamp washer Jack 2) Screw Screw Back 3) Side bracket Side bracket Right 4) Molding Right 5) Molding Left 6) Tow eye cap 7) Cover Right 8) Upper grille Center 9) Outer Outer Right 10) Upper grille Rivet 11) Lower grille Center 12) Outer Outer Right 13) Absorber 14) Impact bar 15) License bracket 16) Spoiler Black 17) Splash shield 18) Bolt Bolt Back 19) U-nut U-nut Back 20) Support Right 21) Nut Nut Back 22) Inner seal Back 23) Temp sensor
You should show the year of the car in your sig.
This is for a 2007.
UltimatePedals, USASpec PA-20GM iPod/Connects2-BTAV1, Llumar ATR15 tint rear, H&R spacers, Borbet-XL/Dunlop M3 18x8" winters, SAAB Euro Badge, Ital black frames, TurboX watch and driving gloves...Dart Vader's own anyday now
Ambisaab's Avatar
Mine's the same.
I'll shut up now !
Old 4th November 2009
I've been putting off the repair. Today I jacked the car up so I could look around underneath. I took off the damaged air shield, that looks easy to replace. The kicker is the lower front black grille. I think that is part of the whole bumper. Looks like the black grille pops over some plastic vertical pieces which are built in.
I can replace the engine air shield and the front spoiler lip but will still have the "hanging" front spoiler problem. I think if you've banged the front a bit, it breaks the plastic vertical structure behind the black grille. That would account for the dropping 1/2" or so. Bummer is... I may have to replace the whole bumper to fix that!
What do you think?
Ohh, and to answer an earlier question. I've looked around for the parts. Seems SaabUSA parts is the cheapest I've found.
Old 17th November 2009
kevputo kevputo is offline
My Saabs: 2005 93 Linear
The vertical posts of the bumper cover are broken on my car as well. The previous owner hit a parking barrier or something, just enough to pop the vertical posts and put some 'spider web' cracks in the paint, and one crack in base PP material in the corner of the passenger side. I had him knock $500 off of the purchase price to allow for repairs, since that's what I guessed it would cost to have a new cover painted & installed. But after doing a little more research here it looks like that was too low. Seems like I'll pay more than that for an unpainted cover if I buy new. Oh well, live & learn.
I'll eventually get the bumper cover replaced, but am hoping to get through the winter with a temporary repair. That way I won't feel as bad if I happen to accidentally bump a parking curb, since I'm still getting used to this car.
I think I'm going to pull the bumper cover off this weekend and try doing a temporary repair myself. Looks like I should be able to put some screws into the vertical supports from the top side, and use some fender washers or something along those lines to re-attach the posts where they broke off from the main surface of the bumper cover. Hopefully that will provide enough support to hold the bottom lip up under the wind load at highway speeds, and prevent any further damage.
Anybody think that will work, or am I wasting my time?
Am I right in my concern that I will cause further damage if I just keep driving the car in it's current state? Or should I just not worry about it until I can get it fixed the right way?
volcomstone2262's Avatar
volcomstone2262 volcomstone2262 is offline
My Saabs: 06' 2.0T
Those black inserts were a pain in *** for me to get off. I took the complete front apart.
I figured I'd have to take the whole front bumper cover off to work on it. The cover sits pretty much right up against the actual bumper in the area I'm going to try to add screws to. Should be plenty of space to work with once I get it off, and I may not even need to mess with popping the black lower grill pieces off of the cover.
Any special tips for getting the bumper cover off? From looking at the car and the diagram posted above, it seems like there are just a few screws, some plastic rivets, and some snap features holding the entire bumper cover assembly on.
If I'm oversimplifying this and there are some hidden screws or something, I'd be glad to hear about it before I end up causing more damage to the cover in the process of trying to fix it.
Dustin's Avatar
Dustin Dustin is offline
My Saabs: 9 Arc 2.0T 6MT
There are no hidden screws. There are the nuts and screws to get out in the wheel wells, and the plastic rivets on the top of the grille area. Then it sort of "pops" out of the joints on the fender areas, and comes right off.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
