Factory weld stressing? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 04-08-09
ahal's Avatar
ahal ahal is offline
My Saabs: 1990 Saab 9000 Carlsson 2.0 FPT
Question Factory weld stressing?
Hi everyone,
While taking the rear driver - side wheel off my 9000 carly, I had a good look inside of the wheelarch. There's a join in the body ( wheel well ) behind the suspension, and it appears to have come apart a bit
I know the car got a belt from behind at some stage - not light but not 'runaway truck' either. I'm pretty confident the car's not dodgy ( had it checked by professionals ).
I know as much about body construction / welds as the average Eskimo knows about sunburn. I thought I'd throw it out there, in case anyone on the forums who knows these things could opine as to whether this is as a result of the bang, or if sometimes welds in presumably stressed areas can shift over time?
Thanks as ever,
Tony.
Old 04-08-09
Jim Mesthene Jim Mesthene is offline
I've seen it on very high-mileage cars. A vertical tear in the middle? Check the other side.
A decent Body Shop can fix it pretty cheap. Get the cracks fixed, they travel.
Corporations are people! If you prick them, do they not bleed? If you tickle them, do they not laugh? If you poison them, do they not die?
Old 05-08-09
ahal's Avatar
Thanks Jim.
That's exactly it - a vertical lift where one panel overlaps the next along the seam. The car's a 166,000 miler, wasn't joyridden but wasn't treated with kid gloves either ( this was confirmed when I found two completely black fruits, and a 1991 WHSmith receipt under the passenger seat )
I'll certainly get that done ... I'm thinking a good poke around the rest of the wheelarches might be a good idea too. I'd never have spotted it if I didn't have the problems I had releasing the back wheels ( all wheels in fact ) from the hubs
Regards,
Tony
