brake judder - SaabCentral Forums
Old 22nd July 2009
mgmt585's Avatar
mgmt585 mgmt585 is offline
My Saabs: somewhere, over the rainbow....
Default brake judder
Hi guys,
I need your expert assisstance. Whenever i brake hard from 75mph+ I get a tremendous juddering through the steering wheel, if anyones in the passenger seat they say they can feel it too. it happens from any speed down to about 30mph then it goes away. i've driven a lot of other cars and braked hard, and never had this before. the discs definitely aren't warped. is this a common problem with the crappy single pots up front or are my brakes just especially ****? the juddering is worse the higher the speed. Not confident building at all, rather off putting
Thanks
EDIT: Only happens when braking really hard. not pedal fully down, but pushing the brakes as far as they will go without ABS interfering.
Saabrina Stage 4 9-5 - SOLD 3rd july '10
Old 22nd July 2009
mt.aero's Avatar
mt.aero mt.aero is offline
My Saabs: '02 9 Aero, '89 900S
how do you know they def. arent warped? Did you have them turned? Sounds exactly like warped rotors to me.
Old 22nd July 2009
mgmt585's Avatar
they are new rotors and pads on all fours ("motorsport" spec on abbott racing site). It happened before and after new discs. have had them checked for warping at three different places including a saab garage when getting a new oil breather pipe, and they are def not. sounds like warped to me as well which is why i am confused. The brakes are bedded in properly as well.
i wondered if just all 9-5 brakes suck? i have a heavy estate car with non aero brakes, so i thought it made sense?
Old 22nd July 2009
mt.aero's Avatar
loose carrier bolts perhaps. Check all of your bushings. A bad or loose one may allow your suspension to shudder on heavy braking.
Old 22nd July 2009
mgmt585's Avatar
ok will do. thank you very much. will update this in the future
Old 22nd July 2009
raquettelaker2's Avatar
raquettelaker2 raquettelaker2 is offline
My Saabs: 2008 Turbo-X, 1994 c900 CommEd
Warped rotors. 100% positive. Period. End of story. Good day sir. Or ma'am.
Old 22nd July 2009
jsmith jsmith is offline
My Saabs: 2003 9-5 LNR BCB STG 1
agree on this one. warped rotors sometimes only manifest when heated up (hard braking). ok when cooled down - so they can't tell when they measure run-out.
Old 22nd July 2009
Tailspin's Avatar
Tailspin Tailspin is offline
My Saabs: '03 9-5 Aero, 08 9-3, '89 C900LM
My mechanic told me my zimmermans were warped and said the only way to get rid of the vibration would be to turn them (but mine cant cause they are crossdrilled). It turned out that the brakepads wore unevenly. They were ceramics and I didnt bed them in properly . Vib showed up maybe 6 months later.
You could get a set of new pads with a bed-in surface (redstuffs do) that grinds the disc a little and mates the pad to the disk evenly. Although if your discs are warped, youll be out a set of pads because I am pretty sure you can only bed in a set of pads once.
24hrs of LeMons SAAB 900 project:
Updated 12/7/14
The Q took a hard hit last race but managed to still finish well, a triumph to the spirit of this old bbq'ing jalopy. Will it be able to recover from the frame bending accident? Will it ever manifold BBQ again??
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
