| Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum |
Hey All,
New Saab owner here. Just got a '91 9000 after much research and debating Anywho, I had a question for all of you. I'm not sure how to describe it, but it's a little light on the dash that says shift up. Well, the quirky thing is, it's telling me to shift up when I'm getting low rev's (around 2k) and I know it's definetly not time to shift up :-? . Is there anyway to adjust the threshold of this little neat feature, or is this just the way they all are? Secondly, when I go to unlock the doors, the hatchback motor/servo makes a terrible hi pitched wine/screech when unlocked. It's like the motor is trying to turn too far or something like that. Are there any solutions to this or do I need to buy a new servo? Finally, it appear as if one of the windows is off the track. The motor works fine (according to the seller) but the window is apparently not even connected. Any adivce or tips? Thanks! |
| Sponsored Links | ||
Advertisement | ||
Welcome JayKay,
What model car are we dealing with here, CS, CD ?? I have similar cars of the same year and haven't got a change up light on any of them. What exactly is the symbol that is lighting up, location and colour? Its not the low water level light for the windscreen washers that flashes up as you accelerate by any chance is it?? To check the window, take the door panel off. You need to reomove 2 screws on each end of the storage tray, 2 screws hidden in the door handle, unclip the electric mirror switch to uncover another screw, remove door unlocking cover to uncover some more screws then the door open light cover is to be removed and look carfully inside and you will find another screw buried behind the polythene sheeting. Door card then unclips from the bottom and lifts up over the door lock tab. Unclip wire block connectors as you go. Sound more complicated than it actually is. note:The window motors are virtually bomb proof compared to 900's so check the arm connection to the glass support. |
Depending on what window you are working on...if its the drivers door then check the locking mechanism at the same time...the linkage start to seize up giving the unlocking motor a hard time...oil all the linkages and see how you get on.
Oops, forgot to mention the specs
It's a 1991 9000 n/a 5 spd (the base model). The light in question is a little yellow indicator that has a small pictures of a stick shift and the workds "SHIFT UP" and it comes on when the tach starts to approach and/or leave the econo markings, but sometimes it comes on when I'm in low revs and too early to shift. It's on the same line as the rear window defroster light, a few inches left of it. One more thing, my SRS light flashes then sticks on, I was told that all I need to clear this fault is to unplug battery for 30 mintes and it should be back to normal. Is this right? |
I also have this somewhat irritating 'shift up' indicator...I read somewhere that it was made available on US models only (they must think Americans drive too many automatic cars!)
Not sure if you can adjust the setting, but anyway you'll probably find you ignore it after a while. |
It's on US cars so that EPA testers will shift up and the car gets better gas milage on their tests. You could live by the light, and do the engine some good, but don't worry so much about it, ignore it. You could take out the bulb from it, but it seems more work than it is worth.
About those window motors. I don't know what the other poster was talking about, but mine were cable operated. There are 3 mounts to the door itself. These are 2 metal studs with rubber sandwiched in the middle that make up each mount. Often times what happens is that the rubber comes disconnected from the stud, allowing the motor to rotate, eventually, this shreads the cable and the window won't open or close. This happened to my front passenger window. The studs also broke in my driver door, I found this out and replaced them with solid steel studs. I also suspect this of my driver rear door, which works sometimes with help.
Stealth |
The “Shift-up” light should just say “shift” because it senses RPM and speed and then comes on… either way… upshift or downshift
Stealth |
yes I know it says "shift up" but it will light up when it feels you should be down shifting too.
Mine 93 does the same thing, they did it with fuel echonomy in mind. Honestly, I just ignore mine most of the time. Also in regards to Markk's responce, the shift-up light only comes on American Saabs.
Looks like this btw:
![]() <edit>look here, now it goes on at 6000rpm! I don't know if I'd pay 40$ US for it though - http://www.lehigh.edu/~erp4/saab/Upg...hiftLight.html </edit> |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
