Cooling fan - SaabCentral Forums
Old 3rd June 2009
jbroski jbroski is offline
New Member
My Saabs: saab 900
Default Cooling fan
Hey guys, long time lurker, 1st time poster here. Today my cooling fan decided to quit working. rather than going through the trouble of replacing the resistor & all that, can I just use a universal 12" or 14" electric fan? Any help would be greatly appreciated.
Old 3rd June 2009
earthworm's Avatar
Saab Sage!
Years ago, I installed a 99 fan on the 93, but I had plenty of room and the controls were simple.Today, this is no longer true. To repair the resistor seems to be much easier and doable..
http://www.geocities.com/pmiczek@sbc...es.html?200727
Thanks to PMI of Wisconsin
Welcome to SaabCentral, JBroski of Texas.
The earthworm
'96 900S, Automatic
Old 3rd June 2009
New Member
My Saabs: saab 900
I was actually just looking at that site, but can't find a resistor with those specs anywhere. Radio Shack doesn't have one, neither does Fry's I need to get the fan fixed asap, as this is my daily driver.
Old 3rd June 2009
earthworm's Avatar
Saab Sage!
I am not generally impressed with Radio Shack...
Why no, buy a heat sink pad from them, which they probably do not carry ..a make your own set up using several resistors in series ??
Or visit your local yard.
The Saab design could be better, much better.The resistor should be on a heat sink and the wire insulation could be better...
The 9-3 uses a different set-up, and I doubt if it would fit.....
The earthworm
'96 900S, Automatic
Old 3rd June 2009
jstrowe jstrowe is offline
My Saabs: 1995 ng900 2.0 'vert, 2000 9-5 2.3T
You can get them from Digikey. They offer next day delivery if you call them by 8:00 PM. The resistor itself is $5.47 plus shipping.
http://search.digikey.com/scripts/Dk...e=TMC50-.20-ND
John
Old 3rd June 2009
New Member
My Saabs: saab 900
Hey, thanks for the link Got the resistor ordered.
Yeah, Radio Shack is pretty worthless. The first guy I spoke with there acted like he didn't know what a resistor was lol
Old 16th July 2009
Wing0tj Wing0tj is offline
My Saabs: 97 900s
Default Resistor replacement wiring
I am thinking I have the same exact problem with my AC, at first I thought it was in need a charge, so I hooked up the gauge and I noticed the fan was cycling on and off instead of running constantly (I'm in phoenix and it was 113 today so it I would assume it would just run constantly).
I am pretty sure that the resistor is fried.
SO my question is, does anyone know of a wire diagram for the setup found here
http://www.geocities.com/pmiczek@sbc...n/fan_res.html?
I am pretty confident I understand what is shown here, but I am a little weary of what exactly is going on with the white/gray wires.
Is there a 3-way splice hidden underneath the black shrink wrap on the new setup?
Thanks Taylor
Old 27th July 2009
ldinnc ldinnc is offline
My Saabs: 96 900S
I don't believe there is any splice under the shrink wrap of the new setup but rather I believe there are two white wires joined at the yellow crimp connector. Power either flows through the white wire directly to the fan motor for high speed operation or through the green wire, through the resistor, up the white wire to the crimp connector then down the other white wire to the fan motor for low speed operation.
Old 28th August 2009
Saab Max's Avatar
Saab Max Saab Max is offline
My Saabs: SAAB 900SE V6 2.5L / 9³SE 2.0/03 9-5Areo
Question
Hello guys im just curious.....
My cooling fan runs on high when it comes on ..... never low im guessing or i never see it running low speed before.... how do i know if the resistor needs changing......? Or is this normal for it to act like this?
earthworm's Avatar
Saab Sage!
I hope I am 100%correct about this. The fan high speed bypasses the resistor( I am positive). The ECU with input from sensors, controls the speed.
There is excessive heat, particularly with the turbocharger and this could be damaging things.
I'd remove the fan and resistors and do a close examination.
Normally the fan should run on low and then switch to high when necessary.
The earthworm
'96 900S, Automatic
Saab Max's Avatar
Thanks alot EW..... Im guessing my fan resistor is bad then, because it only goes on high then turn off when necessary.......
earthworm's Avatar
Saab Sage!
Possibly, its easy enough to check out...great tool, the VOM.
The earthworm
'96 900S, Automatic
Old 31st August 2009
Saab Max's Avatar
Its me again.... i was thinking earlier and was wondering..... Does the LOW speed runs only when the A/C is [ON]......... or it constanly runs with/without the A/C ? .... THEN runs HIGH when necessay (Meaning the temp when up a few degrees) Thanks
Originally Posted by Saab Max View Post
Its me again.... i was think earlier and was wondering..... Does the LOW speed runs only when the A/C is [ON]......... or it constanly runs with/without the A/C ? .... THEN runs HIGH when necessay (Meaning the temp when up a few degrees) Thanks
When the engine heats up, the fan first comes on at low speed. If low speed is not sufficient and the temperature keeps going up, the high speed fan comes on. After the engine is shut down and the water stops flowing, the temperature often goes up and the low speed fan kicks on for a few seconds. When the A/C is turned on, the pressure in the condenser goes up. The condenser pressure is related to its temperature with higher temperatures causing higher pressures. If the condenser temperature/pressure goes up past a certain point, the low speed fan (and only the low speed fan) comes on to cool the condenser. The fan need not run continuously with the A/C on, but it will run most of the time.
John
Saab Max's Avatar
John
Thanks alot John
Old 2nd September 2009
Saab Max's Avatar
Question
Im getting ready to attempt this job.... got the resistor but where can i get the other parts such as :
White & Black wire, 12 AWG, automotive
Green wire, 14 AWG, automotive
M6 screws and nuts (2)
14 AWG crimp connectors (6)
Heat shrink tubing
Aluminum plate, 30 x 100 mm (~1.25 x 4")
Heat shrink tubing
It's in the description of the first two parts: an automotive supply store. They should have everything with the possible exception of the aluminum plate. You might have to try a hardware store to find something that will work.
John
Old 3rd September 2009
900chango 900chango is offline
My Saabs: '88 SPG, '94 900CE 'vert, '87 900t
I did this job one year ago. I got my resistor from www.mouser.com.
I followed PMI's guide but ran into some issues about where some of the wires went...this is my thread:
http://www.saabcentral.com/forums/sh...d.php?t=130544
I have not had any problems, but I'm still not sure if my LOW speed works since my AC doesn't blow cold since I bought the car 2 years ago.
For the low price of all these materials this job is worth doing rather than buying an aftermarket fan.
1988 900 SPG
1994 900 COMM ED. 'VERT
1987 900 Turbo - 24HRS LEMON's RC
1996 900 SOLD, '99 9-3 SOLD
Saab Max's Avatar
Can you send the direct link from mouser.com... its a pain to find the exact resistor on there site.... i bought mines from digikey.com... thanks alot
Old 8th September 2009
Default link to power resistor
http://www.mouser.com/Passive-Compon...+RH-50&FS=True
1988 900 SPG
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
