Big Brake kit - fluid question - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-5 Mk.I, 1998-2009 > Saab 9-5 Performance, Mods & Tuning
Saab 9-5 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-5
Old 01-06-09
attim attim is offline
My Saabs: '00 "Social" 9-5 Aero
Default Big Brake kit - fluid question
Planning to install front big brake kit in a month or so (after delivery).
For the brake kit it's recommended to use DOT 5.1 fluid but as far as I know SAAB recommends DOT 4.
Is it possible to fill whole brake system with DOT 5.1 safely ?
9-5 Aero | 19" BBS CH | 3" J-T turbo-back | Bilstein HD's | Big brake kit front | Nice intake pipe | other mods comming ...
Old 01-06-09
MI-Roger MI-Roger is offline
My Saabs: 2008 9-5 Aero Sedan, 2006 9-3SC 2.0T
Default DOT 5.1 is compatible with DOT4
Do a full flush just to be sure, but the two fluids are compatible.
DOT 5 is a completely different fluid and NOT compatible with either 5.1 or 4! There are conflicting opinions on whether DOT 5.1 is a real improvement over DOT 4 but I can't remember why.
Old 01-06-09
sleeper9kt's Avatar
sleeper9kt sleeper9kt is offline
Dot 5.1 is 100% compatible with DOT 4. But, as noted don't make the mistake between DOT 5 and DOT 5.1, they are very, very different.
DOT 5.1 has a higher standard boiling point than DOT 4, but is otherwise the same type of fulid. If you don't do a full flush you aren't going to see the full bennefit of upgrading to DOT 5.1, but you can still mix them with no problems.
Myself and many of my local Saab buddies have been running DOT 5.1 for a few years now due to our cars seeing some brake abusing track time.
2001 325XiT - slow / 1995 9000 Aero - 426whp /
1999 9-3 - stage 3 / 1973 99LE
1994 900 V6 - Team Cougar Bait - 24 Hours of Lemons
Old 01-06-09
Kermit's Avatar
Kermit Kermit is offline
Saabista
My Saabs: Citroen C5 2.2HDi
I ran DOT 5.1 with Goodridge lines for a couple of years, it certainly firmed up the pedal response.
1...../ 5
Old 01-06-09
karmat karmat is offline
My Saabs: 1978 Saab 99 Turbo (US)
This article has a lot of good info and explains what the difference is between Dot 3/4, 5, and 5.1:
http://www.american-auto-club.co.uk/...ask=show&id=70
And this thread has good info about the respective boiling points of various brands of brake fluid:
http://www.advrider.com/forums/showthread.php?t=139701
Hope that helps
Karl
