New 1990 SPG owner in need of assistance - SaabCentral Forums
Old 24-05-09
redsaab36 redsaab36 is offline
My Saabs: 2001 saab 9-5
Default New 1990 SPG owner in need of assistance
Hi all
My son and I recently purchased a 1990 SPG for his first car. It is a little rough
around the edges but a great runner. I need to get a new clutch for it and was
wondering if anyone from the Vermont area might be able to assist me with this task. I have never done a clutch before looking for some guidance and or some help. I have searched the forum and found alot of great info on clutch replacment but still a little worried i might screw it up any help would be appreciated
Thanks matt
Old 24-05-09
Earth Brown's Avatar
Earth Brown Earth Brown is offline
My Saabs: 04 9-5 Arc(stg3 275hp 300ftlbs) 92 900s
1st, buy complete kit, including the slave.
If I were in the area I could help.
K
Old 24-05-09
900t's Avatar
900t 900t is offline
Saabista
Originally Posted by redsaab36 View Post
Hi all
Thanks matt
You have like the car with the easiest clutch to change in the world. There is a good writeup on this site, you guys should have it over and done with in a day, assuming zero experience
Old 25-05-09
saab900turboguy saab900turboguy is offline
My Saabs: 1990 Taledage Red SPG, 2008 Turbo X 6sp
Where abouts in vermont are you? I am about 10 minutes from fairhaven vt on the NY, VT border.
Old 25-05-09
I am located in underhill not to far from fairhaven
so i should buy the whole clutch kit? flywheel also or not?
Old 25-05-09
I can't say whether you need a flywheel or not because i havn't seen it. It is always good to get it turned down though. It wouldn't do any harm to get a new flywheel but if you don't have to spend the money then don't. If the flywheel is rough and warped an all that take it to an auto shop and see if it can be turned down. If it can't then you need a new flywheel.
Old 26-05-09
thanks for the info im going to order the kit and wait on flywheel, will check it out when I work-up the nerve to tackle this job.
Old 26-05-09
if you need a hand message me im not to far away from you. My schedule is pretty free so anytime really. Im not an expert on clutch replacements but i have done it before so i know a bit about it. Its really not that hard to do once you get into it.
Old 27-05-09
thanks i appreciate it
Old 28-05-09
dasander dasander is offline
My Saabs: 1987 Saab 900 Turbo 3dr
I live less than ten miles from you, and have done this job many times, Let me know if you want a hand.
