New Car: Dark Oil Color After Oil Change? - SaabCentral Forums
Old 23rd May 2009
archanglues2 archanglues2 is offline
New Member
My Saabs: 2005 9-3 Aero
Question New Car: Dark Oil Color After Oil Change?
So I and my wife just got our 2005 9-3 Aero about 2 weeks ago. 62k mile lease return that appears to be in nearly excellent condition. We have driven it around 750 miles since we got it and it runs great.
I checked the oil after we got it and the oil level was in the middle between the min and max level indicators but was very dark in color, still somewhat translucent but still very dark. So a couple days later my wife took it to wal-mart and they supposedly changed the oil and my wife made sure to tell them to put mobile 1 synthetic in it.
So I check the oil again after the oil change and it is above the max level and nearly identical in color as before we had the oil change. They also charged us for 2 more quarts than what is included in the service (5 quarts?).
Is this at all normal?? Is something wrong with my car? Or did Wal-Mart just rip me off?
Also of note, I've never owned a car with a turbo or a car that uses synthetic so if those affect the oil color that may need to be accounted for.
Old 23rd May 2009
raquettelaker2's Avatar
raquettelaker2 raquettelaker2 is offline
My Saabs: 2008 Turbo-X, 1994 c900 CommEd
I've got a 9-5, so a little different, but my oil gets pretty dark too. I wouldn't worry too much about it. But please, whatever you do, never bring your Saab to WalMart of all places to have the oil changed. You're asking for trouble. Congrats on the new car though!
Old 23rd May 2009
DanS DanS is offline
My Saabs: 2007 9-3 2.0T Past: 2001 9-3
Saabs hold 6 quarts. My car has 60K and it is clear goldish color. Runs pretty clean.
Old 24th May 2009
JMarkert's Avatar
JMarkert JMarkert is offline
My Saabs: 2004 9-3 linear
It's pretty normal for oil to darken up quickly, my 2004 did the same thing when I bought it last year. The used car dealer I bough it from changed the oil, but it seemed to get dark quickly.
Since I didn't know the history or what kind of oil he used, I wound up changing the oil again after a couple months, just to be prudent. I'm not sure it was really necessary to do so though, but I worry a bit about this stuff. I will say that it seems to stay a bit lighter for longer now that I'm on ~7-8 K changes, but my impression of what's on the dipstick is pretty darned subjective.
I'm sure if you've been browsing the forums, you know all about using Mobil 1 0W40 and the like.
Old 24th May 2009
JonV JonV is offline
Saabista
My Saabs: 03 SE 5 Spd
By the way, not just Mobil 1 Synthetic, but it should meet the GM LL A/B 025 Spec. Not all grades of Mobil 1 Synthetics do.
Technically the capacity is 6.3 qts, so they may have cracked open a 7th.
Old 24th May 2009
baldwin8's Avatar
baldwin8 baldwin8 is offline
My Saabs: 2004 9-3 2.0t
Automotive oils normally have detergents in them that will cause your new oil to go dark very fast. If your lease return car had few oil changes then there would be a build up of dirt in the engine that will take a while to clean even with frequent oil changes. Most people wait way too long to change their oil. A very knowledgeable engine mechanic told me dirt was one of the major contributors to engine wear.
As for the Walmart work ethics. I wonder if their used oil container is very full? Lets hope so. If garages can not be trusted to do simple oil changes, that is very sad.
Old 24th May 2009
DougR's Avatar
DougR DougR is offline
My Saabs: 06 9-3 2.0T
Oil will get dark pretty quick, but I would advice highly against going to walmart for oil changes, not just with the Saab, but really with any car. I actually take mine to the dealer because it's not much more expensive than buying the stuff myself, and I know they are putting in the right stuff.
Old 24th May 2009
New Member
Here is the picture for reference. Keep in mind this oil only has about 4 days/400 miles on it.
Old 24th May 2009
JMarkert's Avatar
Interesting, mine looks the same after around six weeks (though I don't think I actually looked at it after four days.
After you change the oil, it looks like it's time to paint that fence
Old 24th May 2009
DougR's Avatar
Here is a crappy out of focus picture of my dipstick in similar lighting. This oil was changed about 600 miles ago. As you can see, it's still a bit "translucent/golden", the way your oil looks is more the way mine looks around 5-6k. So either your engine is really dirty, they didn't change the oil, or whatever type of oil they used looks like that.
Old 24th May 2009
DougR's Avatar
Also, my advice if you want peace of mind is to either do another change with 0w40 M1 and a quality filter, or else take it to Sewell saab off the tollway since you are in Plano, have them change the oil.
Old 24th May 2009
Saabista
You'll save at least 20-25 bucks by not going to a Dealer, more if you DIY...
Old 24th May 2009
sausajes sausajes is offline
My Saabs: 2006 9-3 aero - stick/vtuner 0
What is a good oil filter? hows fram?
Old 24th May 2009
Saabista
Just order a couple of OEM Kits from Genuine Saab......
http://www.genuinesaab.com/catalog/p...roducts_id=260
Old 24th May 2009
DougR's Avatar
The dealer in plano only charged me $71(tax included), and that includes a complimentary car wash/vacuum out. The M10w40 near me was close to $7 a quart, so when I did the math and added in the filter, $71 didn't seem bad at all.
Old 24th May 2009
Saabista
You can DIY for under 50....
I get the Saab "Flight Check" 79.95, includes Tire Rotation, Tread and Brake measurements, various Hose/fluid Inspections documented and a car wash coupon.
Old 24th May 2009
JMarkert's Avatar
Also, if you order the Mann filter from eeurparts.com it comes with the big o-ring, I think. However since your filter would have been just changed, I don't think the O ring is especially vital. You should probably order the rubber gasket for the drain plug. These last more than one oil change, but again you have no idea how old the one you have is or how badly overtorqued the plug is.
As for DIY, you might save some $, but you'll probably wanna buy some ramps and sockets if you don't have them. You'll need some torx bits to take off the engine cover, a great big socket to take off the oil cartridge cover, a smaller one for the drain plug etc. We can provide details and a protocol. Nothing terribly unusual, but the oil filters a bit odd (but common in GM land).
You'll save a few bucks, but the best reason to DIY is peace of mind - you'll know that you got the proper kind of oil in there, that the old grunge had enough time to drain out etc.
Old 24th May 2009
JMarkert's Avatar
Is anyone else impressed that DougR checks his oil before he even puts on his shoes?
Old 24th May 2009
jlrdrony's Avatar
jlrdrony jlrdrony is offline
as I can see in the photos:
-too dark oil.
-----for diesel engines is like normal but, not for gasoline ones (honey translucient color and perdure for long time and many kms).
-overpass the maximun stick level (one liter more damage the engine).
I am very impressed about your recomendations about oil change. sorry!!!
but, I pay 160 for gm specitication supersythetic longlife 5w-30, (In america would be an scandal), and some of you use 10w-40 (semi-synt. for diesel engines, not for turbo gasoline engines) for less than half price.
Old 24th May 2009
Saabista
"I am very impressed about your recomendations about oil change. sorry!!!"
....^^^^WTF does that mean?
"some of you use 10w-40 (semi-synt. for diesel engines, not for turbo gasoline engines) for less than half price. "
...^^^^Whos using 10W40 Semi Synth??? Wasnt mentioned in this thread?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
