GS Strut Brace Install - SaabCentral Forums
Go Back   SaabCentral Forums > Saab NG900, 1994-1998 and OG9-3, 1999-2002 & '03 Convertible (NG=new gen/OG=old gen) > NG900 & OG9-3 Performance, Mods & Tuning
NG900 & OG9-3 Performance, Mods & Tuning Covers Tuning & Performance modifications for the NG900 (1994 to 1998) & OG9-3 (1999-2002) & '03 Convertible
Old 22nd May 2009
fromero's Avatar
fromero fromero is offline
My Saabs: '02-93 Conv. 310Hp/435Nm
Default GS Strut Brace Install
Hi,
just got today my strut brace from Nick, for my 93 vert...BUT I find it difficult to fit It's like the brace is a couple of mm short and I cannot bolt the f..nuts
Anybody know how to do it properly?
'02-93-2.0T Conv. Maptun Stage 5. '06-95Aero intake. 3" Stainless steel downpipe & race cat. Bilstein/Eibach. ETS Intercooler-Forge Dumpvalve. 22mm ARB. Six point subframe brace. Viggen 308mm front brakes & 95Aero 300mm rear brakes. Full suspension kit, Strut bar & Steering Clamp & brace by GenuineSaab..Lots_O_Fun
Old 22nd May 2009
lms's Avatar
lms lms is offline
This seems to be a problem with some of these bars. Makes me wonder just how much the body of these cars flex and stay that way. I had to heat mine some to get it into place. Be carefull as someone posted a pic of a broken stud with one of these bars that 'I think' did not fit right.
Old 24th May 2009
LJ[MaVErICK]'s Avatar
LJ[MaVErICK] LJ[MaVErICK] is offline
My Saabs: 2002 9-3 SE Convertible
Yea, some people have had lots of problems with these. Others i think just got lucky. Call nick and see if he can help you.
Old 25th May 2009
NickTaliaferro's Avatar
NickTaliaferro NickTaliaferro is offline
My Saabs: GenuineSaab.com
The cars are so soft and are easily damaged from potholes to minor crash damage. All those braces are welded in a solid jig so they are all the same dimensions based off factory undamaged cars (actually an average of 4 mint cars for the 9-3). It is the cars that vary quite a bit. Some of the cars that come in to my workshop for fitting are a little bent. If you compare dimensions to the crash book. Sometimes lifting the car with a jack can get them to drop on. Also fit the 4 outer bolts then rock it up under the firewall. The cars are not exactly new anymore..
Nicholas Taliaferro GenuineSaab.com Since 2001 and nobody could spell Tali... |
2.0 GOOSE 500whp + 8500rpm = 11.06 @125 in -09 on a gt30 and stock gears
E85 Viggen 488whp / 440wtq 12.43@114 | Nordic/GS E85 9-3 SS Aero 317hp / 350ftlbs | -72 v4 Wagon 95 120hp <The most fun of all
Old 25th May 2009
saabchilten's Avatar
saabchilten saabchilten is offline
My Saabs: '96 900SE 2.0t Convertible a.k.a. Aeron
sounds like i might have some trouble when i order and fit one then. who knows how far the strut towers in my 900 have moved. i do have a jack, and i've heard these braces do wonders. i certainly hope so.
"and when the sun shines...you can peel off the rest of your inhibitions"
Old 26th May 2009
AZR Racing AZR Racing is offline
My Saabs: 1997 saab 900se
Garage
i wouldnt think it would be too bad for people with the factory strut brace....
900 SEC 2.xT, custom 3inch exhaust, GT35r BB turbo, custom log manifold, tial Q bov, autometer phantom boost,oil,WB, JZW full custom tune, siemen 60# injectors, aeromotive 340 intank, want fried rice?
Old 26th May 2009
fromero's Avatar
Thanks Nick, I used a jack under the right front side, and a little patience, together with a couple of long necked 13's and it slid right through.
NOW, WHAT A DIFFERENCE!!
I felt it immediately, the steering is smoother, less prone to wheel torque, straight as an arrow, high speed on a straight line is tight, feels more solid now, and the curves...well, the curves.. Letīs just say I had some real fun!! I recommend this for all convertibles..
This weekend we'll install the other one in the yellow Viggen!! I hope to have similar fun....
Thank you Nick, a sound design, good quality craftmanship, and great results...
Now, for the 300mm vent rear brake kit...this weekend....
Old 26th May 2009
now find a bumpy road and tell us what the cowl shake is like! i'm getting really aware of it and the torque steer. glad to hear yet another good review.
Old 27th May 2009
Sure is crazy how soft the chassis is!? Since statically jacking one corner is not really much load compared to a dynamic event like cornering on race tires or hitting a pothole.
On those rear brakes have tinsnips to make room in the dust shield for the larger calipers is only modification (you can hold them up and see its only a little part alternatively you can just bend them.), the rest bolts directly.
Old 31st May 2009
fromero's Avatar
Thumbs up
No cowl shake, almost no wheel torque...
Of course, this is the last of many additions:
6 point subframe bars.
GS bushing suspension kit (w/reinforced bolts)
GS steering clamp & brace
GS strut bar
eibach springs & bilstein shocks
Thank again, Nick...
Old 31st May 2009
Immo's Avatar
Immo Immo is offline
My Saabs: 02 Viggen CV
With the help of a great friend (who has a lift in his home garage) I got my 6-Point Subframe Brace, 22mm Rear Anti-Roll Bar, and Steering Rack Brace / Clamp Kit on yesterday.
WOW, what a difference!
2001 9-3 HOT SE 5 Door Sold - 2003 9-3 2.0T Arc 4 Door Sold - 1985 900 SPG Sold - 2002 9-3 Viggen Convertible
Old 1st June 2009
jaross's Avatar
jaross jaross is offline
My Saabs: 2000 9-3s 2.0t, 89 SPG
will the strut brace keep the chassis from flexing out of shape in the future?
compared to the 6 pt brace how much of a difference is there is there with it road feel wise?
- J-rod
6 point frame brace, steering rack brace, rear anti roll bar, cold air intake, koni kit
Old 1st June 2009
sweed88 sweed88 is offline
My Saabs: 99 saab 9-3 2.0T
These strut tower bars are great. i bought one awhile ago about 2 years ago and was very impressed with the results. so much so that i want to make one for my everyday car. Its a 4500lb Maxima. i was wondering what kind of steel its made of and also the wall thickness. i understand if nick doesn't want to give up this info but if anyone has any helpfull hints as to which material i should use i would appreciate it. if all goes well id like to try to make a 6 point brace for my project9-3.
Old 8th June 2009
Meek Meek is offline
My Saabs: .
The car will drive better if you remove the extra 1000+ lbs you have in it..
Meek
94 900SET
96 855R
Old 8th June 2009
like i said its my everyday car not a track car. the car weighs what it weighs. im not going to strip down a luxury sedan by 1000 pounds. makes no sence. just trying to improve the handling a little bit and kill some extra time i have.
Old 8th June 2009
Clovii's Avatar
Clovii Clovii is offline
My Saabs: 1997 Saab 900 SE Talladega 4dr
I don't think he weighs a thousand pounds....
Old 9th June 2009
you're so clever.
Old 9th June 2009
lms's Avatar
lms lms is offline
6 point: you feel it right away. Squid bar: You kind of feel something, but it's not transforming your car by any means. Out of all suspension mods, it's the least noticable imo.
Old 9th June 2009
you think it's more noticeable on the convertible when the roof isn't there to stabilize the a pillars and strut towers?
Old 10th June 2009
fromero's Avatar
Today I installed the other GS strut bar in the Viggen...No issues installing it (shows a better chassi) and less flex.
Good addition, but not as dramatic than the convertible.
Thanks Nick !!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
