Whack Tach - SaabCentral Forums
Old 21-05-09
Mrb00st Mrb00st is offline
My Saabs: 1988 Saab 900 SPG
Default Whack Tach
i was hoping i could get some input on this...
my 1988 SPG has a nearly non-functional tachometer. It works about a quarter of the time... mostly it just sits at 0, but when it is active it bounces around a lot. The car is running smoothly so I tend to doubt it's the ignition amplifier module, but I am wondering if there are any connections i should check to see if I can pin this problem down. Any help would be appreciated...
-James
1988 Saab 900 SPG, Edwardian Gray 5 speed manual
135,000 miles, 2.0L 16v Turbo/APC, Bone Stock! (For Now)
www.carthrottle.com
Old 21-05-09
IronJoe's Avatar
IronJoe IronJoe is offline
My Saabs: '87 Airflow Convertible, '08 Turbo X SC
Garage
James,
The ign amp module sits in the inner fender and can get hit with corrosion - I'd unplug it and check the connections, it's an easy (and cheap) test.
*1988 BMW M3* - Current project
*1987 Airflow vert project thread* - 400bhp, Eurotuner Magazine Feature Car - Now on T5
*1987 SPG project thread* - Sold
*1999 Lightning Blue 9³ Viggen* - Sold
Old 21-05-09
Rodentmaster's Avatar
Rodentmaster Rodentmaster is offline
My Saabs: Rip:'86 EMS Now? 2x 93 2.1 5dr & Vert
There is a little PCB circuit INSIDE the tacho that can get......
dry joints and from memory a little edge connector on the board which could cause grief.
It is close to torture to get the tacho apart without damaging the needle but it can be done.
Then there is the cluster left hand edge connector itself which could be worn or on the fritz.....
Woah! Don't expect men to talk to your face if you patronise that establishment!
RodentMaster, post links responsibly!
Eat the Pudding!
ODE to the N\A
"I have not TURBINE to compress my buttocks, O lord,
Pity will be thine when thoust can crap on with boost.
We of the 'N\A - N\A' knowst nil of the pulling glory,
Yea, to post, thy blight the day of those who pressurise their pipes,
Alas, suck be mine that my chariot breathes,
Strike me down for mine is an unworthy existance"
Old 21-05-09
checked the ign. amp connection - it was clean and shiny. cleaned up the whole thing, tightened it back down and hooked it back up - still no tach.
so irritating! This'll be my next project.
www.carthrottle.com
