Mirror Corrosion
1 reading
36K views 35 replies 26 participants last post by  Dan19_82
#1 ·
So my corrosion on my mirror was getting really bad. Cost is way too high to replace and I am out of warranty, so I decided to fix.
What needed:
Painters Tape (Blue)
Plastic Bag
T-30 torx bit
flat head screwdriver
220 & 320 sandpaper
Black Flat spray paint (I used rustoleum)
Black primer ( I didn't use, but I would recommend. This also helps fill some of the little holes left from the corrosion.)
Started by pulling off the door panel.
1. Removed the handle trim to access and remove the two bolts behind it.
2. Pop off door panel starting from the bottom outside corner and lift off.
3. Unplug all electrical connectors should be 3 or 4 and remove door handle cable.
4. Pull down and out to remove the mirror control panel.
5. Remove connector to mirror (circled in blue)
6. Remove plastic plug/clip (circled in yellow) using a small flat head screwdriver or a pick.
7. Use a T-30 torx bit to remove the 3 bolts (circled in pink) holding on the mirror. Hold mirror while unbolting the last bolt to prevent from falling.
8. Remove rubber/foam gasket.
9. Start removing the corrosion. I started with a flat head screwdriver to take off all loose corrosion and the started sanding with 220 and finished with 320.
10. Once all the corrosion was removed, Made sure all surfaces were scuffed with 320 and cleaned off with soap and water.
11. Pop plastic piece off the mirror that sits on the under side of it.
12. Wrap mirror in plastic and tape off to protect.
13. I painted on about 4 coats and waited to dry. (Follow directions for applying coats)
14. Clean rubber gasket with water and soap.
15. Put back together and install.
Now the pictures.
Terrible corrosion.
Connectors and bolts that need to be removed.
After sanding.
Finished Product.
On the car.
Goodluck
#2 ·
Worthy of a sticky!
What's shocking is that the car has corrosion but is only a 2003 model. Saabs are supposed to be impervious to corrosion! (Why, the first ever instance of corrosion in a classic 900 did not occur until 2007!:cheesy: and I used to walk to school in the snow barefoot....and uphill....both ways)
#6 ·
Dang, how can I prevent this ? Nice job, thanks for posting Dex4.
#19 ·
I've done this today.. hehe... stupid corrosion..lol
the harder part for me was to remove the door panel.. was my first experience on this and dont want to break the clips..
Now my mirror are nice!!! better then oem with my paint... match more with the mirror hehe
I had a problem with my mirror glass... was loose.. so take it off and glue it ... look fine now
I wont post pics.. its the same things as the other one!!
you have to pull the door handle trim.. the thing where you put your hand to close the door (where the window button are..)
#21 ·
Sorry but I had to laugh when I read this thread because you guys are worried about a little corrosion...
I have some serious problems....I noticed my mirror was vibrating more than usual while driving the other day. Instead of pulling over to check it out I had a flashback of highschool of how my mirrors used to look when the bass hit and ten seconds later my mirror flew off :eek:
Cinderella's famous "Don't know what you got till it's gone" hasn't popped into my head in years but that was the first thing I thought of :D
Man is it tough driving without that mirror!
#36 ·
great guide done mine today
never took the door card fully off didnt have to.
Thread revival. As old as this is my 04 saab suffers from this.
I am wondering if I'm being lazy in thinking it could be sprayed in situe. With carefully placed and taped paper. After rubbing this down I thought I could maybe spray it matt back without removing it..
Am I mad?
#25 ·
Digging up an old post but better than starting a new one?
Anyway, has anyone tried to remove the painted housing that holds the mirror from the piece that is corroded? Reason I ask is I have a sand blaster that would probably do a quicker and more complete job than scraping and sand paper.
Just curious before I dive in to this project......
Thanks! Great write-up!
#28 ·
#30 ·
The mirror consists of thre parts, the aluminium part ( that doesn't rust but corrode), the black frame around the mirror itself and the mirror housing, often colourcoded. You will have to pop out the mirror to separate the frame from the housing, it's a real pain and takes a bit of twisting and swearing and you need to keep your cool not to snap plasticparts here and there ;)
So you will get a little more room removing all the plastic, but the folding sceleton part so to speak, will always be attached to the corroding base.
If that made any sense at all ;)
And I think matt paint is more durable than plasti dip.
