automatic transmission cooler..is it worth it? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-3 SportSedan/Convertible ('04+)/Combi, 2003-2011 > Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning
Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-3 Sports Saloon/Sedan, Combi & Convertible
Old 18-05-09
ckrocks ckrocks is offline
Default automatic transmission cooler..is it worth it?
is tranny cooler necessary for A/T cars with large performance gain(in both 4 banger and v6 trims)? is there even a company that makes a kit for 2003+ 9-3?
Old 18-05-09
cjhutch's Avatar
cjhutch cjhutch is offline
My Saabs: '02 9-5 Aero Wagon
Easy answer is it won't hurt. Anything to make parts of your car run cooler is going to help. I'm sure you could just buy one of the universal tranny coolers and then have some lines made up. Just make sure you decide on where you are going to place it because you will want to get exact measurements.
Old 19-05-09
9-3gotboostAERO's Avatar
9-3gotboostAERO 9-3gotboostAERO is offline
My Saabs: 06 2.0T, 08 9-7 5.3i
there is no kits being made. Im looking to do this by the end of the summer b.c. i dont trust my tranny holding more the 300hp...
Gonna have to fab it up myself it looks like.
06 9-3- Audio overhaul, 2.5" straight pipe with D2 tip, "Blues" drop... its slow.
08 9-7x 5.3i-Fully loaded w/ Navi, might make it a real saab and boost it
91 c900T Vert- Saved my life, RIP
Old 19-05-09
NickTaliaferro's Avatar
NickTaliaferro NickTaliaferro is offline
My Saabs: GenuineSaab.com
No real need to change the cooler. The integrated oil to water will do plenty. It also serves to warm the trans quicker on cold starts. The other issue is if you make the fluid too cold (Winter driving with no thermostat) you can cause the gearbox to go back to cold shifting patterns. Stock is fine.
Nicholas Taliaferro GenuineSaab.com Since 2001 and nobody could spell Tali... | TrollTuner.com
2.0 GOOSE 500whp + 8500rpm = 11.06 @125 in -09 on a gt30 and stock gears
E85 Viggen 488whp / 440wtq 12.43@114 | Nordic/GS E85 9-3 SS Aero 317hp / 350ftlbs | -72 v4 Wagon 95 120hp <The most fun of all
Old 20-05-09
thanks for all your input.
Nick, I believe there are a number of people on this forum who have had their auto tranny replaced regardless of whether their cars are stock or modded. This led me to think that the 5spd auto in nature is pretty weak, but then i noticed in the other thread that the max torque tolerance on the box is quite high. What do you think might be the culprit in the failure if the torque limit is so high?
Old 20-05-09
O rings mainly. such a small part makes such a huge difference...
Old 21-05-09
smurkenstein's Avatar
smurkenstein smurkenstein is offline
My Saabs: 03 9-3 Aero
Most of the transmission woes were with 03 (and some 04) cars with the coolant leak scenario - this should have been fixed in the newer cars
Old 21-05-09
Dach Dach is offline
My Saabs: MY04 93SS Aero
I had mine done, and no regrets. I used a generic Oil Cooler.
I didn't have to worry about warming up to ATF much. I'm from a much warmer climate.
You don't need to get too large a set up cause you don't want a huge pressure drop in the gearbox.
Old 21-05-09
ah i see. thanks again everyone.
Dach, how hard was the installation? did you use existing coolant lines?
Old 22-05-09
I didn't do it. From what I've seen, its relatively easy, but don't take my word for it.
Old 03-02-10
Nibiru's Avatar
Nibiru Nibiru is offline
My Saabs: 2006 9-3 Aero V6
Default I disagree
I don't think a cooler could hurt, especially if you do any modifications which increase horsepower.
Old 03-02-10
Cosmicflash Cosmicflash is offline
My Saabs: '09 9-3 SS Aero XWD
I agree with Nick--no reason at all. Unless you have an used analysis that shows it's breaking down and is burnt don't bother. There have been virtually no issues with either of these trannys according to everyone.
If you're concerned change the fluid more frequently.
03' SS Linear Cosmic Blue, 109k mi., gone
06' SC Aero Auto Fusion Blue, BSR tuned, 94k gone.
09' SS Aero XWD Auto
Carbon Gray, Black Premium Leather, VTuned, 30% tint.
Old 03-02-10
Nibiru's Avatar
Default Disagree
Here is a link.
http://www.supercheapauto.com.au/diy...ooler-kit.aspx
I have heard time and time again that lowering the tranny fluid by 10 degrees will double the life of your transmission. Though it isn't necessary, there is a benefit. And if you drive the car like I do then it is probably a good idea. Also with an auxillary cooler you would probably have to change the fluid less. I think eventually it would pay for itself, but to each his own.
And if Saab is like most other cars, the cars primary tranny cooler is in the radiator or cooled by the radiator fluid so making this cooler via an additive or using deionized water will help lower the temps.
Old 04-07-11
j-y's Avatar
j-y j-y is offline
My Saabs: 2005 9-3 Hirsch
Do I need to disconnect the original/existing cooling lines if I were to install a trans cooler?
Old 04-07-11
kimvette's Avatar
kimvette kimvette is offline
My Saabs: 2005 Saab 9-3 Linear
The conventional rule of thumb is for every 20º cooler the transmission runs, the service life is doubled. I don't know if that holds true for the latest generation of slushboxes.
http://bit.ly/gcgArf - 9-3 HID upgrade how to photos
http://bit.ly/g0BAob - Daniel Stern's article on light color
Old 04-07-11
pugsaabaero's Avatar
pugsaabaero pugsaabaero is offline
My Saabs: 2007 9-3 Aero JZW e85
Garage
i think this is a great idea hopefully someone has done this and can chime in also i heard that additives to the rad like water wetter gel up in there? thought about additive as a why not this sucker runs hot anyways.
Old 05-07-11
HuNtS's Avatar
HuNtS HuNtS is offline
My Saabs: Silver 2003 9-3 ARC
Garage
I've never heard of anyone having tranny issues on here tuned or otherwise.. Keep the fluid in good shape, and make sure your radiator and coolant are up to par and you'll be fine.. I would spend my money elsewhere. Just my $.02
Old 05-07-11
mike saunders's Avatar
mike saunders mike saunders is offline
Saabista
My Saabs: N/A
Here is a link.
This was definitely true when autoboxes without auxiliary cooling were installed on trucks and other tow vehicles...and transmissions had to be changed every few seasons.
Things have come a loooong way since those days, with most manufacturers installing auxiliary coolers from the factory on vehicles that need them.
Old 20-07-11
jmcdoogie's Avatar
jmcdoogie jmcdoogie is offline
My Saabs: 2008 Turbo X, 2006 2.0t, 2004 9-5 Arc
I've read that too. But 20deg lower than what? i.e. what's the optimum temperature to run the ATF at? I've ALSO read you don't want to get crazy with it until it warms up.
In fact, step back for a moment and consider what's really going on. The Saab Workshop Manual considers "normal operating temperature" 70deg - 80deg C (or 145deg - 160deg F).
Well, the problem as I see it is, the Coolant in the Radiator runs 25deg C (40deg F) hotter than that. So, maybe the ATF is actually helping cool the Engine Coolant in the Radiator !?!?! i.e. - the ATF is running at about 100deg C (210deg F) at it's coldest
I sure hope that wasn't the intended effect.
So, are we suggesting that lowering the ATF Temp 20deg means lowering it's operating Temp to 75deg C (150deg F) ?
Or is there a different "magic" temperature for optimum Tranny life that we're trying to hit?
I have been talking about installing a big fat external ATF Cooler in the past on this Forum. But, I'd like to know IF my ATF is running hot first, and by how much. Does anyone know, is there an ATF temp sensor already in the Tranny that I could log from the OBDII port?
BTW, I did my first "mini-flush" of the ATF at 23,000 miles a couple weeks ago, and it was burnt - not horrific, but burnt. (this was after I did a "spirited" 500mile romp to Hermiston, OR and back from Issaquah, WA, including a 100mph+ leg from Prosser to Paterson the full length of Hwy 221) When I got back, I changed out only 4 Litres of ATF, but I felt like it made a slightly noticeable difference in shifting smoothness, particularly when downshifting when cold (which is most of the time out here in "The Land without Summer") So, I'm going to change out another 4 Litres this weekend, try to freshen the ATF up as much as practical.
Again, what is the ideal ATF Temp?
HE DRIVES THE MOST INTERESTING CAR IN THE WORLD
I don't always drive limited-production high-performance automobiles ... but when I do, I prefer the Saab Turbo X ... stay Turbocharged my Friends!
Old 20-07-11
Jn2's Avatar
Jn2 Jn2 is offline
My Saabs: 07' 9-3ss Aero
JZW Aggressive tune, GS 3" downpipe, MPx Blow off plate, DIY intake, 18x8 Moda Md6's, TWM short throw shifter, Aeroforce Interceptor gauge
