Turbo problems? - SaabCentral Forums
Old 06-05-09
worriedinmi worriedinmi is offline
New Member
My Saabs: 2004 93 linear
Default Turbo problems?
We recently bought a used 2004 93 linear which we really love. Unfortunately last night it started smoking heavily from the tail pipe - white smoke and lots of it. My husband is convinced it is the Turbo. Everything I have read here leans me towards that as well.
Your thoughts and advice appreciated.
Thank you
Old 06-05-09
jstrowe jstrowe is offline
My Saabs: 1995 ng900 2.0 'vert, 2000 9-5 2.3T
Turbos do not usually fail so suddenly. Is the coolant level going down? If so, it might be a head gasket.
John
Old 06-05-09
New Member
Isnt it motor oil burning and not engine coolant?
Old 06-05-09
White smoke can be either coolant or oil. Inspection of the fluids and smelling the smoke will tell which it is. In either case, turbos tend to fail slowly whereas HGs tend to fail quickly. A bad HG can burn either oil or coolant. It can also leak oil into the coolant and the other way around.
If the coolant in the reservoir has oil floating on it or if the oil looks like cafe au lait after running, it's pretty much a sure bet that the HG has failed. A compression test would also be in order to complete the diagnosis.
If you pull the elbow that directs the air into the throttle body and there's a lot of oil on the throttle plate, that would argue for a blown turbo. If the oil seal on the turbine side is shot, it's a lot harder to inspect.
John
Old 06-05-09
Darren900's Avatar
Darren900 Darren900 is offline
My Saabs: 2000 9-3 T7 5-Speed 5-Door
You should probably repost here for more specific info for your car:
http://www.saabcentral.com/forums/forumdisplay.php?f=30
Old 06-05-09
New Member
I wasnt sure if I was in the right place - thank you!
